Carb from a Torana? https://www.ausmini.com/forums/viewtopic.php?f=2&t=32326 |
Page 1 of 2 |
Author: | Harley [ Thu May 31, 2007 4:00 pm ] |
Post subject: | Carb from a Torana? |
A guy at work has a 1.75 in SU he doesn't need. He knows nothing about it and I don't know much from looking at it either. Does anyone know what type they ran and if it could be of use to me on a mini? Thanks. ![]() |
Author: | Hanra [ Thu May 31, 2007 4:17 pm ] |
British technology on a and Aussie (european) muscle car... Hmmm. Dunno bout that one. Im only assuming S.U.'s were a british idea? |
Author: | Spaceboy [ Thu May 31, 2007 4:21 pm ] |
yeah they had triple su's |
Author: | Hanra [ Thu May 31, 2007 4:28 pm ] |
True ay!! But was that stock on the GTR XU1? or GTR? I would of thought triple strombergs not S.U.'s???? |
Author: | Sprite_Man [ Thu May 31, 2007 4:30 pm ] |
That right. Triple SU's. ![]() If you change the needle over you should be okay. If you got a pic, we might be able to tell you HIF44 or whatever Inlet manifolds might be different also, so just get a new one. EDIT: They were on torana's also I think |
Author: | Hanra [ Thu May 31, 2007 4:36 pm ] |
LC GTR: Two Bendix-Stromberg WW2. LC GTR XU1: 3 x 150 CDS (1.5 inch) (38.1 mm) Zenith sidedraughts. LC GTR XU1 Race Spec: 3 x 150 CDS Zenith sidedraughts, revised needles. LJ GTR: Single downdraught. LJ GTR XU1: 3 x 175 CD-2S (1.75 inch) (44.45 mm) Stromberg sidedraught. LJ GTR XU1 Race Spec: 3 x 175 CD-2S (1.75 inch) (44.45 mm) Stromberg sidedraught. |
Author: | Blokeinamoke [ Thu May 31, 2007 5:03 pm ] |
I think the Viva based Towana had an SU? |
Author: | Hanra [ Thu May 31, 2007 5:05 pm ] |
Thats cause the Torana is a European car as with all Holdens cars. The HB Torana was taken from the Vauxhall Viva. |
Author: | slinkey inc [ Thu May 31, 2007 6:34 pm ] |
Triple SU's were a popular mod to 202 Torana's back then, or so I'm told. Well SU's look better anyways, haha. |
Author: | 850pete [ Thu May 31, 2007 6:59 pm ] |
Post subject: | carb |
Triple SU's are a popular set-up for Holden Powered sixes, I've run 1 3/4SU's on a 202 in the past. The Carbs are exactly the same carbs, just different needles will be needed. The factory triple carb set-up was indeed CD Strombergs but the aftermarket stuff is also SU's and Webers. They also ran Triple Split Choke Webers on the Bathurst race cars too. |
Author: | d1ck0 [ Thu May 31, 2007 7:03 pm ] |
Depending on the Carby/manifold that was used, it would be worth your while to check the float chamber angle. Won't necessarily be the same as a Mini. If not you can buy the little plate that sets this level. |
Author: | Morris 1100 [ Thu May 31, 2007 7:09 pm ] |
No Holden came from the factory with an SU. Holden had a tie in with Stromberg so that was all they could run. Lots of Holdens were hotted up with twin or tripple SUs. |
Author: | Harley [ Fri Jun 01, 2007 7:33 am ] |
Thanks for the responses sofar guys. ![]() Here's a couple of dodgy snapshots of it: ![]() ![]() |
Author: | 850pete [ Fri Jun 01, 2007 8:00 am ] |
Thats definately a CD stromberg carb. Your best bet would be to buy it, sell it on ebay and then buy a real SU carb. You'll probably have enough cash left over for a sixpack too |
Author: | Blokeinamoke [ Fri Jun 01, 2007 8:06 am ] |
Yep thats a stromberg - the second photo shows it clearly. |
