Removing Underbody Sound Deadener
https://www.ausmini.com/forums/viewtopic.php?f=2&t=32370
Author:  mtnmini [ Fri Jun 01, 2007 5:24 pm ]
Post subject:  Removing Underbody Sound Deadener
I'm currently stripping my mini body for a repair and respray. I wanted to remove the sound deadener on the underbody to carry out rust repairs and replace it, and a guy I know said to use the oxy to heat up (not burn) the deadener and just scrape off with flat tool or the like.
I commenced yesterday, and the stuff just peels off like magic. It's a bit messy keeping the tool clean but had the stuff off in no time. Just had to ensure all flammable bits on the inside were off as well.
Brian
Author:  drmini in aust [ Fri Jun 01, 2007 9:09 pm ]
Oxy is a bit drastic, a decent electric heat gun works pretty well. My Makita gets so hot i can silver-solder with it... :shock:
Author:  tom11111 [ Fri Jun 01, 2007 10:14 pm ]
I fixed rust on the bottom of my 1000s, all i did was clean it off with a wire wheel on a grinder the weld new metal on. Any left over under sealer just burns out of the way.
Author:  gafmo [ Sat Jun 02, 2007 12:47 am ]
Heat Gun the Wire Wheel it
Author:  cush [ Sat Jun 02, 2007 12:52 am ]
is that underneath a van?
Author:  Mini Mad [ Sat Jun 02, 2007 3:28 am ]
yeap
Author:  gafmo [ Sat Jun 02, 2007 7:21 am ]
section nearest to the roller door is where the tank goes
Author:  gafmo [ Sat Jun 02, 2007 9:12 am ]
here's a before pic also
Author:  mtnmini [ Sat Jun 02, 2007 4:20 pm ]
It was a cool flame from the oxy, but after seeing the photos - sounds like a heat gun and wire brush is the go. Could eat your dinner off it!
