It is currently Sat Jul 19, 2025 4:25 pm
 Post subject: aerial hole
PostPosted: Mon Jun 04, 2007 7:57 am
g'day i am currently restoring a 1970 mini k. i have put a roof mounted aerial insted of the one on the nose. i bogged up the hole the first time and it cracked so i welded a plate underneath it and then bogged it up and it cracked out again. how do i fix this hole without it cracking out?
PostPosted: Mon Jun 04, 2007 9:22 am
Hard to believe - maybe the filler is shrinking? Try some of that fibreglass reinforced stuff which I think you can still get from Super(not so)Cheap.
PostPosted: Mon Jun 04, 2007 10:10 am
Try tacking/bronzing a thin disk/washer into the hole from the top to the plate you have underneath first so that you don't need your filler as thick.
PostPosted: Mon Jun 04, 2007 12:58 pm
I welded my hole up, just kept moving around until no hole, then flap disk grinded it an skimmed some bog over that.
PostPosted: Mon Jun 04, 2007 5:28 pm
oh ok yea i mite try and bog it once more and see how it goes
 Post subject: at the station??
PostPosted: Mon Jun 04, 2007 6:02 pm
Is there movement in the guard somewhere else??
Could be flexing and no amount of bog will stand up to that.
Did you give it sufficient curing time??
PostPosted: Mon Jun 04, 2007 6:34 pm
Resident Test Pilot
For $10.00 I plugged mine up with a Chrome blank. Game Set Match. No more hole. Doesn't look bad at all.
PostPosted: Mon Jun 04, 2007 7:57 pm
what is a chrome blank?
 Post subject: Plug
PostPosted: Mon Jun 04, 2007 8:16 pm
Mate..... its a plug that you buy in Auto stores for hiding a hole...it has a chrome side that you bolt over the offending orifice.
PostPosted: Tue Jun 05, 2007 11:40 am
Resident Test Pilot
[img][img]http://i138.photobucket.com/albums/q280/matt850_photos/P1010011-1.jpg[/img]
A Chrome Blank[/img]
Users browsing this forum: drmini in aust, watsupskip and 72 guests
