aerial hole
https://www.ausmini.com/forums/viewtopic.php?f=2&t=32459
Author:  carter [ Mon Jun 04, 2007 7:57 am ]
Post subject:  aerial hole
g'day i am currently restoring a 1970 mini k. i have put a roof mounted aerial insted of the one on the nose. i bogged up the hole the first time and it cracked so i welded a plate underneath it and then bogged it up and it cracked out again. how do i fix this hole without it cracking out?
Author:  AEG163job [ Mon Jun 04, 2007 9:22 am ]
Hard to believe - maybe the filler is shrinking? Try some of that fibreglass reinforced stuff which I think you can still get from Super(not so)Cheap.
Author:  VicMini13 [ Mon Jun 04, 2007 10:10 am ]
Try tacking/bronzing a thin disk/washer into the hole from the top to the plate you have underneath first so that you don't need your filler as thick.
Author:  minimetoy [ Mon Jun 04, 2007 12:58 pm ]
I welded my hole up, just kept moving around until no hole, then flap disk grinded it an skimmed some bog over that.
Author:  carter [ Mon Jun 04, 2007 5:28 pm ]
oh ok yea i mite try and bog it once more and see how it goes
Author:  9YaTaH [ Mon Jun 04, 2007 6:02 pm ]
Post subject:  at the station??
Is there movement in the guard somewhere else??
Could be flexing and no amount of bog will stand up to that.
Did you give it sufficient curing time??
Author:  matt850 [ Mon Jun 04, 2007 6:34 pm ]
For $10.00 I plugged mine up with a Chrome blank. Game Set Match. No more hole. Doesn't look bad at all.
Author:  carter [ Mon Jun 04, 2007 7:57 pm ]
what is a chrome blank?
Author:  9YaTaH [ Mon Jun 04, 2007 8:16 pm ]
Post subject:  Plug
Mate..... its a plug that you buy in Auto stores for hiding a hole...it has a chrome side that you bolt over the offending orifice.
Author:  matt850 [ Tue Jun 05, 2007 11:40 am ]
[img][img]http://i138.photobucket.com/albums/q280/matt850_photos/P1010011-1.jpg[/img]
A Chrome Blank[/img]
