Problems with my Gearbox https://www.ausmini.com/forums/viewtopic.php?f=2&t=3255 |
Page 1 of 2 |
Author: | BrettV [ Sat Dec 04, 2004 9:04 pm ] |
Post subject: | Problems with my Gearbox |
Hi Everyone, I have just bought a mini panel van and it crunches in 2nd gear (im not sure if its the sincro) and to select reverse gear i have to lift the gearstick to the right and pull it back.Is this normal for a mini??????? Please HELP ![]() |
Author: | min13k [ Sat Dec 04, 2004 9:13 pm ] |
reverse is normal crunching in second is normal makka haw haw haw |
Author: | willy [ Sat Dec 04, 2004 9:14 pm ] |
Reverse is normal for some gearboxes. Mine doesnt need lifting tho... The 2nd crunching thing... does it crunch when u are getting too eager with your downchanges from 3rd to 2nd? |
Author: | drmini in aust [ Sun Dec 05, 2004 5:45 am ] |
On rod change boxes `73 on you do lift it to get reverse. On older 850 or remote boxes you bang it across against the spring loaded gate. re the crunching, it sounds like the synchro. 2nd gear is the first to wear out...! Rebuild time... ![]() |
Author: | poeee [ Sun Dec 05, 2004 9:27 am ] |
My van crunches into 2nd, but, if you take it easy and slow the gear changes down, all is well. It doesn't like going back into 2nd from 3rd, unless ya going real slow. Syncro is stoofed on 2nd, but that doesn't worry me much, it will pull outa corners in 3rd just as well as it would in 2nd, it's no speed demon. |
Author: | BrettV [ Sun Dec 05, 2004 9:32 pm ] |
Post subject: | Thank you |
Thank you for your replies that has helped me out heaps. ![]() ![]() ![]() ![]() |
Author: | fuzzy-hair-man [ Mon Dec 06, 2004 10:14 am ] |
I remeber trying to find reverse when I first bought my mini clubman (the owner hadn't told be you have to lift the gear stick up) I sat ther for about 5 -10 minutes in the servo finding nothing but 4th and stalling a couple of times ![]() ![]() Bye Arrin |
Author: | J_A_M [ Mon Dec 06, 2004 10:27 am ] |
![]() ![]() re: the chunching in 2nd......JAM did exactly that when I took it for a fang, prior to it coming off the road for rebuild. I thought the gearbox was stoofed, but others have told me since that it might be clutch related. When my wife drove it, she never crunched it at all.....and she STILL reminds me about that, 2 1/2 years later.... ![]() |
Author: | aaron [ Mon Dec 06, 2004 10:41 am ] |
She didn't crunch it because she wasn't driving it hard enough Cheers Aaron |
Author: | J_A_M [ Mon Dec 06, 2004 10:50 am ] |
AGREE!! |
Author: | Wolfman [ Mon Dec 06, 2004 11:32 am ] |
Yep crunching into 2nd when downshifting is normal if you do so with the revs a bit high, double clutching stops it from happening ![]() ![]() |
Author: | drmini in aust [ Mon Dec 06, 2004 6:07 pm ] |
Wolfman wrote: Yep crunching into 2nd when downshifting is normal if you do so with the revs a bit high, double clutching stops it from happening
![]() ![]() Sorry guys, on Minis built from `63 on, this is NOT `normal', it's `common'! The synchro baulk rings work to prevent this- if they not worn out, you can even change without the clutch, if revs are wrong it will just block the shift from engaging. (no I don't recommend you drive without the clutch..) That is what the term `baulk' means. But when they are worn out... ![]() Crunching= new synchro time! Only $30+ each now for newies... ![]() ![]() ![]() |
Author: | kazjim [ Mon Dec 06, 2004 8:14 pm ] |
"Only $30+ each now for newies..." and the bearings, and the shafts, and the .......................................... About $14,000 later, you've got a nice shiny box !! seriously, about $700 + Labour to fully reco a box sound about right ? J |
Author: | Wolfman [ Mon Dec 06, 2004 8:19 pm ] |
At least, depends on how much labor you get charged. I've heard of guys paying over $900, that was a while ago though. |
Author: | drmini in aust [ Mon Dec 06, 2004 8:44 pm ] |
kazjim wrote: "Only $30+ each now for newies..."
and the bearings, and the shafts, and the .......................................... About $14,000 later, you've got a nice shiny box !! seriously, about $700 + Labour to fully reco a box sound about right ? J Depends... Gafmo's (S/H 4 synchro remote box) cost about $700 just for bits, plus a few hundred labour. That was all bearings, layshaft, 4 synchros,& a comp diff pin. Did NOT include R/R. Selector forks were OK- they cost a lot if worn. But, the ripoff merchants will charge you much more- I have heard horror stories of $thousands to remove, fix, replace.. ![]() |
