Cooper S crankshaft https://www.ausmini.com/forums/viewtopic.php?f=2&t=32587 |
Page 1 of 3 |
Author: | Panthersteve [ Thu Jun 07, 2007 2:10 pm ] |
Post subject: | Cooper S crankshaft |
Hi I saw this crankshaft sell on ebay http://cgi.ebay.com.au/ws/eBayISAPI.dll ... &rd=1&rd=1 What do you all think of this, is it a good price, fair price, high price ![]() Cheers Steve Still Learning |
Author: | dove grey 64 [ Thu Jun 07, 2007 2:15 pm ] |
i think that price is pretty fair, i've heard from a few sources they normally cost about that much |
Author: | Minimic [ Thu Jun 07, 2007 3:58 pm ] |
3 or 4 days ago I saw it at about $519 buy it now. He often relists and ups the amount every day. |
Author: | designer [ Thu Jun 07, 2007 4:53 pm ] |
Post subject: | cooper s crankshaft |
Is the number en40b stamped on the actual crankshaft and if it is can it be viewed on a short motor ? Are there visible differences between it and another mini crankshaft ? |
Author: | simon k [ Thu Jun 07, 2007 6:19 pm ] |
Post subject: | Re: cooper s crankshaft |
designer wrote: Is the number en40b stamped on the actual crankshaft and if it is can it be viewed on a short motor ?
Are there visible differences between it and another mini crankshaft ? it's not stamped, it's cast into it, and yes, you can see it on a short motor I think that's cheap for an S crank |
Author: | Morris 1100 [ Thu Jun 07, 2007 7:29 pm ] |
skssgn wrote: designer wrote: Is the number en40b stamped on the actual crankshaft and if it is can it be viewed on a short motor ? Are there visible differences between it and another mini crankshaft ? it's not stamped, it's cast into it, ![]() |
Author: | drmini in aust [ Thu Jun 07, 2007 7:32 pm ] |
Morris 1100 wrote: skssgn wrote: designer wrote: Is the number en40b stamped on the actual crankshaft and if it is can it be viewed on a short motor ? Are there visible differences between it and another mini crankshaft ? it's not stamped, it's cast into it, ![]() You are right, it's a forged crank. ![]() ![]() I always get a laugh when Poms say they built a Mini donk with "steel crank and rods". What do they think stock ones are, licorice? All A series cranks and rods are forged steel, for those who are wondering. ![]() |
Author: | simon k [ Thu Jun 07, 2007 8:31 pm ] |
Morris 1100 wrote: skssgn wrote: designer wrote: Is the number en40b stamped on the actual crankshaft and if it is can it be viewed on a short motor ? Are there visible differences between it and another mini crankshaft ? it's not stamped, it's cast into it, ![]() OK - can you explain the difference between casting and forging? I really don't know |
Author: | graham in aus [ Thu Jun 07, 2007 8:37 pm ] |
Pour molten steel into a mould and cool to 'set' = Cast Heat steel till soft then bash / squash between big forging tools = forged Bit simplified, but correct! ![]() |
Author: | Morris 1100 [ Thu Jun 07, 2007 8:40 pm ] |
Forging is heating up a lump of metal and knocking it into shape. Casting is melting metal and pouring into a mould of the shape. |
Author: | drmini in aust [ Thu Jun 07, 2007 8:42 pm ] |
graham in aus wrote: Pour molten steel into a mould and cool to 'set' = Cast
Heat steel till soft then bash / squash between big forging tools = forged Bit simplified, but correct! ![]() If you have a choice, forged is stronger than cast. The material's grain follows the shape of the part. For the same reason forged is stronger than billet, if you are talking crankshafts for example. ![]() |
Author: | simon k [ Thu Jun 07, 2007 8:48 pm ] |
wow - forging of a crank must be a pretty neat process to watch.... what does 'drop forged' mean on my spanners? sounds like clever marketing |
Author: | Morris 1100 [ Thu Jun 07, 2007 9:17 pm ] |
http://science.howstuffworks.com/question376.htm |
Author: | drmini in aust [ Thu Jun 07, 2007 9:22 pm ] |
`Drop forged' just means the top die is dropped/driven against the bottom one, drop forging is an impact process. It doesn't tell you what material it is, could be drop-forged chewing gum if made in China. The magic words for good spanners are "chrome-vanadium"... ![]() |
Author: | Mick [ Thu Jun 07, 2007 9:37 pm ] |
I've got a set of russian spanners here made from "Chrom Vandium" apparently ![]() Not all S cranks have EN40B letters necessarily, later ones (68'ish on?)have an AEG480 part number. |
Page 1 of 3 | All times are UTC + 10 hours |
