front end removal ?'s https://www.ausmini.com/forums/viewtopic.php?f=2&t=32733 |
Author: | gzeVan [ Mon Jun 11, 2007 5:20 pm ] |
Post subject: | front end removal ?'s |
just started removing the clubby front off my convertable today , took the strip off the sides and have started to drill spot welds out, what i would like to know is recommended drill bit size in mm have most people helped prize the panels apart around the welds or does it just come quite loose once all welds are drilled out cheers Paul |
Author: | 9YaTaH [ Wed Jun 13, 2007 5:35 pm ] |
Post subject: | Re: front end removal ?'s |
gzeVan wrote: just started removing the clubby front off my convertable today , took the strip off the sides and have started to drill spot welds out, what i would like to know is
recommended drill bit size in mm have most people helped prize the panels apart around the welds or does it just come quite loose once all welds are drilled out cheers Paul As small as possible to break the spot weld (say about an 1/8th) and so that you can lever the panels gently apart. There is a special drill bit you can get with a flat bottom. |
Author: | gzeVan [ Wed Jun 13, 2007 7:27 pm ] |
thanks for that i have got my mate to order one (drill bit) through his paint and panel shop so i can get it a bit cheaper as they are a bit pricey cheers Paul |
Author: | doogie [ Wed Jun 13, 2007 8:08 pm ] |
You can buy a special spot weld drill for around $2o. Doogie |
