It is currently Tue Jul 29, 2025 12:46 am
 Post subject: front end removal ?'s
PostPosted: Mon Jun 11, 2007 5:20 pm
just started removing the clubby front off my convertable today , took the strip off the sides and have started to drill spot welds out, what i would like to know is
recommended drill bit size in mm
have most people helped prize the panels apart around the welds or does it just come quite loose once all welds are drilled out
cheers Paul
57 Morris minor
88 Rover Mini
PostPosted: Wed Jun 13, 2007 5:35 pm
cheers Paul
As small as possible to break the spot weld (say about an 1/8th) and so that you can lever the panels gently apart.
There is a special drill bit you can get with a flat bottom.
PostPosted: Wed Jun 13, 2007 7:27 pm
thanks for that
i have got my mate to order one (drill bit) through his paint and panel shop so i can get it a bit cheaper as they are a bit pricey
cheers Paul
57 Morris minor
88 Rover Mini
PostPosted: Wed Jun 13, 2007 8:08 pm
High heel ninja
You can buy a special spot weld drill for around $2o.
Doogie
Users browsing this forum: Bing [Bot] and 91 guests
