It is currently Mon Aug 04, 2025 4:14 am
PostPosted: Tue Jun 12, 2007 10:03 am
Hey guys so this morning i turned the key to start up my little beast and there was nothing.... not even a grunt or chortle... silence.
Does anyone know possible resaons? I wouldve thought the battery would die slowly not so sudden... something electrical maybe??
Any help is appreciated.... thanks. :D
feMINIn
 Post subject: Winter
PostPosted: Tue Jun 12, 2007 10:08 am
Winter is the traditional time when batteries die....check there first.
PostPosted: Tue Jun 12, 2007 10:09 am
Clean the battery terminals before you condemn the battery... :wink:
PostPosted: Tue Jun 12, 2007 10:19 am
Yer our Battery die over the weekend...but thats main as the wife has only been doing short Trips so its not had a real chance to charge up also :wink:
PostPosted: Tue Jun 12, 2007 10:21 am
Alrite, ill check that first.
thanking you all. :D
feMINIn
PostPosted: Tue Jun 12, 2007 11:42 am
Grab a multimeter to check..if you don't have one it's worth buying ;)
PostPosted: Tue Jun 12, 2007 12:29 pm
Hi Corky,
Turn the headlights on, do they go? If no, no power(battery or terminal). If they go, have someone turn the key while you observe the headlights. If they stay bright, probably a solenoid/switch fault. If they dim, crook battery or starter problem.
Regards
Al
PostPosted: Tue Jun 12, 2007 3:36 pm
My red/white wire used to vibrate off the solenoid sometimes... :oops: . It would give no outward indication of this till i went to start it up again the next morning or so.
