Tyre pressure for 10" radials? https://www.ausmini.com/forums/viewtopic.php?f=2&t=32786 |
Author: | junglemaster [ Tue Jun 12, 2007 10:01 pm ] |
Post subject: | Tyre pressure for 10" radials? |
Newbie question on tyre pressures... Are all tyres created equal? What pressure should I run in my 10" radials? I do apologise if this has been asked before, but I did search the forum first. Dave |
Author: | 1018cc [ Tue Jun 12, 2007 10:06 pm ] |
I think you should start with a pressure and drive on it for a while. If the ride is too bumpy then let 1 or 2 psi out and see how it goes. That's what I did and I settled on 30f, 28r. I find that this pressure isn't too bumpy and it wears my tyres evenly across the tread. My tyres are 165/70R10 Yokohama A008's. <edit> just found this:Clicky |
Author: | junglemaster [ Tue Jun 12, 2007 10:12 pm ] |
1018cc wrote: I think you should start with a pressure and drive on it for a while. If the ride is too bumpy then let 1 or 2 psi out and see how it goes. That's what I did and I settled on 30f, 28r.
I find that this pressure isn't too bumpy and it wears my tyres evenly across the tread. My tyres are 165/70R10 Yokohama A008's. <edit> just found this:Clicky Whoops, apparently I can't search... So 30 on front and 28 on rear seems to be the general message. Thanks! Dave |
Author: | Mort Subite [ Tue Jun 12, 2007 11:11 pm ] |
junglemaster wrote: 1018cc wrote: I think you should start with a pressure and drive on it for a while. If the ride is too bumpy then let 1 or 2 psi out and see how it goes. That's what I did and I settled on 30f, 28r. I find that this pressure isn't too bumpy and it wears my tyres evenly across the tread. My tyres are 165/70R10 Yokohama A008's. <edit> just found this:Clicky Whoops, apparently I can't search... So 30 on front and 28 on rear seems to be the general message. Thanks! Dave Im going to start with 30/28 and trial 28/26 like i use in my other big cars, dependant on the side wall characteristics of the small tyres. |
Author: | Dylans Clubby [ Wed Jun 13, 2007 12:15 am ] |
i go 32 all round, but its fair bumpy. mght try letting some out ![]() |
