Starter Motor Rebuild
https://www.ausmini.com/forums/viewtopic.php?f=2&t=32954
Author:  goodie [ Sun Jun 17, 2007 3:53 pm ]
Post subject:  Starter Motor Rebuild
What should a starter motor cost to get re-coed?,is there an alternative such as a high -torque to suit a1310 (mine has alway's seemed lazy )or will most mini starter's do the same job?. Any help in this area would be apprciated.
Author:  drmini in aust [ Sun Jun 17, 2007 4:06 pm ]
1. Karcraft for example sells one factory reconditioned in UK, for $127.
I have seen exchange starters lots dearer from various auto electricians.
2. For about $170 you can get a NEW pre-engaged one to suit early Minis, from Heritage MG Parts, at Smithfield.
3. For $240 or so you can get a similar type (but different brand) pre-engaged one from Mini Classic and others.
4. For $40-$50 you can go get a Gemini one from a wreckers, also pre-engaged type. Need to enongate their mounting holes but they bolt straight in.
Your choice... I run option #1 and when it dies I'll use option #2.
:lol:
Note- an S oil cooler won't fit in a roundnose with any of these pre-engaged ones unless you can move it sideways towards the radiator.
Author:  goodie [ Sun Jun 17, 2007 5:01 pm ]
Thank's very much Doc,
I"ll look into the Karcraft option, it wouldn't hurt to have a spare and i'll check with an auto electrician up here as to reconditioning mine.
Author:  smac [ Mon Jun 18, 2007 6:10 am ]
I must get around to doing some reading on the gemini option....you say pre-emgaged, but fits on the inertia style fly?
Author:  Convertible Mini [ Mon Jun 18, 2007 6:45 am ]
Post subject:  Mini starter choice.
I can sell you either a Gemini starter ready modified to fit the Mini engine or I can recondition a lucas M35 one for you for $100 exchange plus post . I also have Special Bosch planetary gear starter motors specially designed for Mini engines Guaranteed to start the biggest High compression Mini engine with ease. These will cost you $275.00 plus post. Check out my Ads in Qld Mini owners Mini trader.
Author:  drmini in aust [ Mon Jun 18, 2007 8:38 am ]
Yes, it fits the early style Mini ring gear and engages from the front- so even if the old ring gear is a bit s/h looking from running the old bendix type, it works OK.
Just need to elongate the flange holes, and check flywheel depth. If flywheel is a long way onto crank you may need to pack the geMini starter out a bit. :wink:
