It is currently Sat Jul 26, 2025 12:55 am
PostPosted: Mon Jun 18, 2007 8:48 pm
Rover Cooper
Gentlemen, what is the best way to give the impression that you have a right hand petrol tank, immitation only. I have 2 monza locking covers and need somewhere to stick the second one so it looks like duel tanks, Suggestions please or advice would be appreciated.
:roll: :roll: :roll: :roll:
PostPosted: Mon Jun 18, 2007 8:53 pm
Minisport in SA sells a dummy RH neck kit. It screws on body with 1 screw. looks real... :lol:
I bought one, cut it up and welded it onto my RH tank (tank filled with water). Now the bugger doesn't leak... 8)
<edit> here `tis on MiniSpares UK site-
http://www.minispares.com/Product.aspx?pid=33029
Last edited by drmini in aust on Mon Jun 18, 2007 8:56 pm, edited 1 time in total.
PostPosted: Mon Jun 18, 2007 8:54 pm
High heel ninja
Just cut the neck off a left hand tank, i had a car that had a hole for the right hand tank, i just pushed the cut off neck into the rubber grommet, it was a tight enough fit to hold it in there, then fit cap, bingo.
Doogie
 Post subject: neck
PostPosted: Mon Jun 18, 2007 9:07 pm
They sell them on Ebay.
Hellooo from OODLES my mini. Is being restored to be revealed in all her glory one day in the future she looks forward to meeting you all.
PostPosted: Mon Jun 18, 2007 9:25 pm
I've seen many mini's with the dummy neck kit.
A bit silly really, looks like twins but without the 50 litre fuel capacity - the real advantage of twin tanks.
But if you have a hole, tis a good way to cover it. Or if you want a Cooper S style, but can't afford a RH tank, go for it. They (RH tanks) are expensive!
PostPosted: Mon Jun 18, 2007 9:47 pm
I can't stand the bloody things.
But this is my opinion only, and in most cases it isn't valid.
PostPosted: Mon Jun 18, 2007 9:59 pm
At least your honest willy.
Users browsing this forum: Bing [Bot] and 95 guests
