help with right hand petrol filler neck
https://www.ausmini.com/forums/viewtopic.php?f=2&t=33016
Author:  Davo111 [ Mon Jun 18, 2007 8:48 pm ]
Post subject:  help with right hand petrol filler neck
Gentlemen, what is the best way to give the impression that you have a right hand petrol tank, immitation only. I have 2 monza locking covers and need somewhere to stick the second one so it looks like duel tanks, Suggestions please or advice would be appreciated.
:roll: :roll: :roll: :roll:
Author:  drmini in aust [ Mon Jun 18, 2007 8:53 pm ]
Minisport in SA sells a dummy RH neck kit. It screws on body with 1 screw. looks real... :lol:
I bought one, cut it up and welded it onto my RH tank (tank filled with water). Now the bugger doesn't leak... 8)
<edit> here `tis on MiniSpares UK site-
http://www.minispares.com/Product.aspx?pid=33029
Author:  doogie [ Mon Jun 18, 2007 8:54 pm ]
Just cut the neck off a left hand tank, i had a car that had a hole for the right hand tank, i just pushed the cut off neck into the rubber grommet, it was a tight enough fit to hold it in there, then fit cap, bingo.
Doogie
Author:  bubbos [ Mon Jun 18, 2007 9:07 pm ]
Post subject:  neck
They sell them on Ebay.
Author:  slinkey inc [ Mon Jun 18, 2007 9:25 pm ]
I've seen many mini's with the dummy neck kit.
A bit silly really, looks like twins but without the 50 litre fuel capacity - the real advantage of twin tanks.
But if you have a hole, tis a good way to cover it. Or if you want a Cooper S style, but can't afford a RH tank, go for it. They (RH tanks) are expensive!
Author:  willy [ Mon Jun 18, 2007 9:47 pm ]
I can't stand the bloody things.
But this is my opinion only, and in most cases it isn't valid.
Author:  slinkey inc [ Mon Jun 18, 2007 9:59 pm ]
At least your honest willy.
