Wiring help - solid red wire that goes to the boot area.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=33047
Author:  Matt68 [ Tue Jun 19, 2007 3:03 pm ]
Post subject:  Wiring help - solid red wire that goes to the boot area.
I have a burnt out wire,
what remains of the insulation shows it to be a solid red wire and it is burnt out behind the dash (passenger side, and in the boot, where it runs to the rear tail light (dual conector).
The car is a 68 deluxe.
Won't have a chance to check a manual for a while but curiosity is killing me.
What is this?
Brake?
Tail light?
Thanks,
Matthew
Author:  cush [ Tue Jun 19, 2007 3:18 pm ]
It's easy to figure out?..what doesn't work back there?
Author:  Matt68 [ Tue Jun 19, 2007 3:35 pm ]
Nope, it all works.... wire is still intact, just had most of the insulation burnt off it :shock:
Drove about 250km since last weekend when the smoke came out, no problem. :shock:
Did a quick check at the time and couldn't see a problem. Replaced the burnt out fuse and away she went, put the smoke down to a stuck needle and seat valve emptying petrol onto the extractors.
Checked it all at lunch today (about to drive to Toowoomba) and saw a tiny bit of burnt wire in the boot, had to look to find the rest but it is there!
Author:  Matt68 [ Tue Jun 19, 2007 3:36 pm ]
Not game to plug the battery back in now I have 'disturbed' the wire, it is probably shorting again now.... with my luck it's shorting on the petrol tank....
Author:  Timbo [ Tue Jun 19, 2007 3:52 pm ]
The red one often burns out. I think its tail lights from memory. Two of my minis and a moke have had that wire burn out. You really need to repair the whole piece of loom because it often melts through the other wires and shorts them together.
Author:  Mick [ Tue Jun 19, 2007 3:54 pm ]
Red is the park light circuit. Goes from the light to the front/rear connection plug, then to a splitter near the center dash hole and then to the light switch under the dash.
Author:  Matt68 [ Tue Jun 19, 2007 4:15 pm ]
Thanks guys.
Will have to pull the headlining and petrol tank and get it sorted properly...
Oh, well, at least it made it to the muster and back!! :lol: :roll: :cry:
Will check other wires in the loom too..... Hmmm, anyone have a spare rear loom?
Matt
Author:  AEG163job [ Tue Jun 19, 2007 5:36 pm ]
Removing the headlining sux. Remember you will have to take off the window seals, undo the glued bits and chance tearing it.
Why not try attaching some strong cable/twine/whatever to the boot end of the loom b4 you pull it out. Do the same for the interior light wires (purple-purple/white), push these wires thru then try pulling the loom (gently) from the engine bay end. Get someone to help pull back the feeder cables while you guide the new loom back in from the engine side :!:
Author:  Matt68 [ Wed Jun 20, 2007 9:33 am ]
Hmmm, that may be the way to do it! I need to replace the headlining and front windscreen, but i can do that later if i can manage to change the loom the easy way!
Thanks!!
Author:  Matt68 [ Wed Jun 20, 2007 9:34 am ]
AEG163job wrote:
.... Get someone to help pull back the feeder cables while you guide the new loom back in from the engine side :!:
What are feeder cables?
Matt
Author:  AEG163job [ Wed Jun 20, 2007 10:12 am ]
the cable/wire/string whatever you attach to the boot end of the loom before you pull it out at the engine bay end.
Author:  Matt68 [ Wed Jun 20, 2007 10:16 am ]
:lol: :roll:
Of course!
Thanks
Matthew
Author:  Wombat [ Wed Jun 20, 2007 11:52 am ]
If you are running a new loom to the back of the car add some additional wiring for a 'spare' while you are at it. Use at minimum a 2 wire lead or get a length of trailer hookup wire with multicoloured wires in a sheath. Have enough to run from battery to front bumper but coil it up and stick it out of the way behind the tank and under the dash until needed. Never know when you may want to add driving lights, a new high powered hi fi or a reversing light or two :wink:
Author:  AEG163job [ Wed Jun 20, 2007 12:12 pm ]
good thinking :) :) :)
Author:  Matt68 [ Wed Jun 20, 2007 12:51 pm ]
Excellent idea!
muchos gracias amigo!
