It is currently Fri Jul 18, 2025 4:39 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Tue Jun 19, 2007 2:46 pm
Just a question out of curiosity. I have seen nulon stop smoke additive in the shops and was wondering if anyone here has used products like this and do they really work.
White_mini_man
PostPosted: Tue Jun 19, 2007 2:48 pm
NO! white_mini_man NO!
PostPosted: Tue Jun 19, 2007 3:03 pm
No such thing as an engine recondition in a can.
PostPosted: Tue Jun 19, 2007 3:12 pm
The liquid stuff you pour in burns just as well as the oil . The metalic gloop you pour in is dangerous (don't think it's available anymore thankfully) , it's claimed to build up metal on warn parts , it builds up metal in oil galleries , bearings and cylinder heads instead :shock: :shock: :shock:
PostPosted: Tue Jun 19, 2007 3:22 pm
Love the replies and I will certainly give this to a wally at work who swears by the stuff. I had my reservations and believed it was a marketing scam but never having any experience with the stuff I couldn't comment either way.
You guys confirmed my suspicions. Thanks
PostPosted: Tue Jun 19, 2007 3:23 pm
actually...
$15 for one of these...
PostPosted: Tue Jun 19, 2007 3:37 pm
i put a full bottle into the morris minor and the thickest oil i could buy and it made no difference at all :oops:
57 Morris minor
88 Rover Mini
PostPosted: Tue Jun 19, 2007 3:43 pm
High heel ninja
Lucas oil stabilizer is a wonderful thing, stopped a bearing knock in a commodore V6 motor i had a few years ago. I have seen it reduce, but not stop a engine smoking, $16 a bottle from Supercrap.
Doogie
PostPosted: Tue Jun 19, 2007 3:50 pm
I've used wynns stop smoke in a Mini and it worked fine. The only problem was that the increased oil viscosity caused major clutch drag and I couldn't change gears without grinding them.
PostPosted: Tue Jun 19, 2007 4:03 pm
Again out of curiosity How bad was the engine smoke, was it only startup smoke or did it reduce continuous smoke?
p.s - how cold is it in Tassie for you guys this week?
white_mini_mad
PostPosted: Tue Jun 19, 2007 4:10 pm
It mostly on startup but was visible any time you accelerated. I ended up using about a half dose to try to get the best compromise between reducing smoking and having the clutch still work. It helped to have clean, high quality oil in it to start with.
Its been pretty cold. I had to turn the heater on in the Moke. Any colder and I'll have to start wearing long pants rather than shorts.
PostPosted: Tue Jun 19, 2007 4:14 pm
A moke, in tassie, nearing winter :shock: , your mad!
PostPosted: Tue Jun 19, 2007 6:28 pm
i put some of the stop smoke in my charade an it stoped using oil ..
for a while :P
its using heaps of oil now :P needs an oil change tho
*it works*:)
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Tue Jun 19, 2007 9:58 pm
resident alien
resident alien
Image their winter is 10 months long! :P
PostPosted: Tue Jun 19, 2007 10:03 pm
If you have a minor smoke issue I find it can slightly reduce the problem for a few months, so it might get one of our less fiscally able brethren (ie me!) a little more time to save up for the engine rebuild but the end result is always the same.
Noli Illegitimi Carborundum
