It is currently Tue Jul 22, 2025 8:48 pm
 Post subject: Ttune up help
PostPosted: Fri Jun 22, 2007 11:47 am
Ok the story goes,
my mini was backfiring so I took her in for a tune up at my local mechanics, not a mini specialist but they usually do a good job...
They managed to fix the backfiring but now she idles eratically, lacks power and sounds a bit like a bug rather than the pur she had before...
Now I replaced the coil recently, plugs are a few months old and leads look fine, so I'm guessing its ignition timing?
The next problem is a slight oil leak from the outside of the inner pot joint (i think thats what its called :? ) is this really a problem or am i just paranoid?
And finally ive got oil coming out of the exhaust its leaving marks on the garage door :( does this mean rebuild time cause i hope not...
Will try get some pics when the camera gets home, i know its a little hard with me just describing it...
Any help would be greatly apreciated and thanks in advance everyone here is usually very helpfull
Cheers Alex
PostPosted: Fri Jun 22, 2007 1:11 pm
heres a photo of the joint u cant really see the oil to well but its dripping from the zip tie on it...
and heres the oil pudle after about 20mins parked in the garage not running...
Now serious or am i paranoid?
PostPosted: Fri Jun 22, 2007 1:14 pm
Cant really help you with the oil leak but have you found the coolant leak as well? It looks like coolant all over the underneath of the subframe.
PostPosted: Fri Jun 22, 2007 1:24 pm
yer i overfilled the radiator and i havnt got an expansion tank so thats just the overflow...
I had the radiator fixed a few months ago
 Post subject: Re: Ttune up help
PostPosted: Fri Jun 22, 2007 1:49 pm
albino235 wrote:
Ok the story goes,
This sounds like a manifold leak to me....
Get a peice of hose and stick it to your ear and shove the other end down near the manifold. move it round until you hear the leak. Fix that issue and the car should come good.
Aaron
PostPosted: Fri Jun 22, 2007 2:26 pm
Check your timing chain cover gasket.
I had oil all over the place in that area when the gasket on mine went. It always left a nice big puddle of oil on the ground after parking it.
If oil is dripping onto that joint while its moving, its going to throw the oil onto whatver areas are exposed to it, makes things look worse than they really are.
No more Minis!......For now.
PostPosted: Fri Jun 22, 2007 3:19 pm
Hmm sounds like a good idea I have heard a bit of whistling from the engine bay recently will check and let you know
PostPosted: Fri Jun 22, 2007 4:47 pm
hmm, cant seem to hear it now, ill order replacement gaskets,
While Im at it I may as well get some leads, plugs, carpet, steering wheel... :D
Users browsing this forum: Bing [Bot], Steam and 62 guests
