If the high beam indicator on the dash isn't coming on, then the twelve volts for the high beam wire probably isn't leaving the steering column. Test for the 12 volts on the blue/white wire at the connector plug for the indicator stalk.
This is under the dash near the steering column. easy to get to on your back from the driver's side.
It may be the dip mechanism in the indicator, or it may be a loose wire herabouts.
_________________ SooperDooperMiniCooperExpertEngineering
