It is currently Sun Aug 17, 2025 6:11 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue Jul 03, 2007 6:28 pm
please no discussion of illegal activities
the fastest i've driven a mini is an indicated 120mph
PostPosted: Tue Jul 03, 2007 6:32 pm
I'm happy driving Sally at the speed limit, she cruises beautiful, no need to go any faster :D
Besides with her little 998 I'm too scared to go any faster then 110km (especially when it hasnt gone round the clock!)
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
185 kph on a timed section of closed freeway (under construction and was classed as private property).
PostPosted: Tue Jul 03, 2007 6:39 pm
SA needs some sort of drag strip. :evil:
I know full speed won't be seen on a drag strip, not even close.
I know there are salt lakes which people do this sort of thing here in SA, but that would just eat my car away.
Don't actually know the top speed of my car, but from the way it pulls in top gear at high-ish rpms, I can jsut guess around the 175kph mark due to my self imposed rev limit of 6600rpm. 180kph at 6800rpm.
Above all I wonder if my car would just fall apart at that speed? Hahaha
I'm a legal driver, so these speeds have never been seem, and probably never will be, unless Adelaide get a drag strip. Or I get un-lazy and do some track work.
PostPosted: Tue Jul 03, 2007 6:43 pm
:roll:
PostPosted: Tue Jul 03, 2007 6:46 pm
130km/h an hour in my little car.. had to test her out when I first got her.... but now I usually just cruise around 90km/h or else she gets too loud.;
 Post subject: Speed and engine revs
PostPosted: Tue Jul 03, 2007 6:56 pm
At 185 Km/hr with a 3.4 Diff and 10 inch wheels tacho would read 7,400 rpm.
"Let us remove your "SHORTS"
PostPosted: Tue Jul 03, 2007 6:58 pm
100 miles per hour in my downton Cooper S 1310cc stae 3 head 1.5" twin carbs, then got the speed wobbles ( but was still pulling) I have got the suspension and geometery sorted now
PostPosted: Tue Jul 03, 2007 7:01 pm
My purple clubbie may or may not have reached speeds of 140km/h going down a hill.
No more Minis!......For now.
PostPosted: Tue Jul 03, 2007 7:08 pm
3.2:1 diff , it was getting close to the 7000 rpm mark :shock:
PostPosted: Tue Jul 03, 2007 7:09 pm
PostPosted: Tue Jul 03, 2007 7:14 pm
skssgn wrote:
should have let the poor engine warm up first :D
PostPosted: Tue Jul 03, 2007 7:15 pm
skssgn wrote:
It runs quite cool at those speeds. 8)
Not many Minis will go much over 170kph due to drag. But if you can slip behind a Holden down Conrod you may pick up a tow. :D
skssgn wrote:
I think i've done 120mph while driving/doing handbrakies in your Cooper S! :lol: :lol:
PostPosted: Tue Jul 03, 2007 7:16 pm
Around 95MPH at the end of Wakefield Pk straight, running 3.44 diff.
That was with the old 1310, which had around 115HP at crank.
The 1360 in it now has a fair bit more HP than that and a shorter diff (3.647) but I've not been there since the rebuild. :wink:
