Making a floor for mini boot
https://www.ausmini.com/forums/viewtopic.php?f=2&t=33192
Page 1 of 2
Author:  Will [ Sat Jun 23, 2007 12:36 pm ]
Post subject:  Making a floor for mini boot
hi all,
I am going to try and make a floor for my boot in my 1978 mini clubman.
Currently there is no floor(in the boot), the boot has the petrol tank on the left, sparetyre in the middle and the battery next to that.Has anyone made a boot floor before? Any advice on how i should go about doing it? What material should i use? Where can i get it?
I intend to cover the board/floor in black carpet type material and later hook a sub and amp up in there.
please post your ideas.
cheers, Will
Author:  sports850 [ Sat Jun 23, 2007 12:43 pm ]
What size fuel tank has your mini got ? If it's the standard 24 or so litre one I can send you a newspaper template of the board I have in the sports850 , it's from a cooper I believe and fits a boot with a single , standard size fuel tank . this one is made from plywood and covered in a tough vynil though others I've seen have been plywood or craftwood and covered in carpet . Depends what you want to do . there is a thread somewhere to of peoples boots and what they've done with full boot kits . I think it was called "show us ya boot" or similar .
Author:  sports850 [ Sat Jun 23, 2007 12:46 pm ]
http://www.ausmini.com/forums/viewtopic ... show++boot
Author:  Will [ Sat Jun 23, 2007 12:49 pm ]
cheers thatd be good. the tank is standard and is around about 20L. yeh i was thinking of a ply and carpet type setup. please send anything helpfull.
Author:  sports850 [ Sat Jun 23, 2007 1:01 pm ]
OK , PM me your postal address and I'll cut out a template and send it to you :D . Mines made using plyood around 8-10 mm thick , I'll take some pics and include them with the template .
Author:  sports850 [ Sat Jun 23, 2007 4:02 pm ]
PM replied to :D
I'll post the pic here too , this is the board I've got and will send you the template .
Author:  72dpi [ Sat Jun 23, 2007 7:25 pm ]
Neat fit Sports850.
You've just inspired me to do up basil's boot. Thats AFTER i get a new Boot seal =)
Author:  sports850 [ Sat Jun 23, 2007 9:38 pm ]
I'm not 100% sure of what it's originally out of but it fits the 850 boot nicely (so not cooper s , only made for a single tank) , 998/7 cooper perhaps ? PM me your address if you'd like a template as well .
Author:  matt850 [ Sun Jun 24, 2007 9:20 pm ]
[img][img]http://i138.photobucket.com/albums/q280/matt850_photos/P1010015.jpg[/img]
Tis is mine. If you only wanted the base I can measure it up and let you know.[/img]
Author:  Toasted [ Mon Jun 25, 2007 2:23 pm ]
sports850 wrote:
PM replied to :D
Whats it sitting on, have you made little legs for it?
Author:  Toasted [ Mon Jun 25, 2007 2:24 pm ]
Ive seen this one before i realy like what you did there. Did you have it done or you made it yourself?
Author:  sports850 [ Mon Jun 25, 2007 2:25 pm ]
Basically it's just on the spare tyre (a widened rim at present but a standard rim works as well) and battery cover . It sit's flat and hasn't caused any problems yet and it's been in there for over 13 years .
Author:  Will [ Mon Jun 25, 2007 5:54 pm ]
matt850, howd you go about making it so neat. Very nice carpet. Did you do it yourself? howd you make it?
Author:  steve1965 [ Mon Jun 25, 2007 6:12 pm ]
Post subject:  boot
Hi Will have ago at making one they are dead simple, just start with the side's first then make the one behind the rear seat, then make the boot floor last. Make them all to a tight fit and they just lock in together you don't need any screws. I made mine in 4 to 5 hours cost was about $70.
Steve
Author:  matt850 [ Mon Jun 25, 2007 9:11 pm ]
Hey guys, I made it myself in one afternoon. Cost around $40.00 -$50.00.
My advice would be to cut large and trim. I made fairly accurate measurements and then small adjustments many times over. The arcs are hard, but work with a piece of string to draw the arc and trimm as required. You will find it is almost a perfect arc anyway.
I used 6mm MDF all round and I curved the front (lip/support) board around the shape of the boot opening / floor board.
Carpet is from Bunnings and is pulled tight and stapled in place.
There are no screws or anything else holding this entire lining in place.
I have say that my non petrol tank side wall has a tendency to move if there is stuff in the boot.
Thought I would rectify this with a couple of small (very small) right angle brackets attached to the floor board. The bottom slides out past the floor board.
I want to keep the cavity on the drivers side as this is where the tool bag goes.
Feel free to ask any questions
Cheers Matt
