It is currently Thu Aug 07, 2025 9:28 pm
PostPosted: Sun Jul 01, 2007 8:21 am
Hi there,
I have been helping my Son with his Clubman, and he had removed the switch panel and disconnected all of the wiring.
i have sussed everything out except the Wiper switch. Can anybody assist with either:
a) Details of which wires go to which contact. The contacts are numbered 1,2, 4, & 5 etc. b) A copy of an Australian Wiring Diagram (77 Clubman) as the OS ones are different.
Any help much appreciated.
Cheers.
Dicko.
PostPosted: Sun Jul 01, 2007 5:46 pm
Any of you clubman owners wanna pull your switch panel out and have a look?
Please......
It's the last thing I need to fix before rego.
Thanks,
Dicko.
PostPosted: Sun Jul 01, 2007 5:50 pm
send wombat a pm and buy his disc it has everything and will help alot
PostPosted: Sun Jul 01, 2007 5:52 pm
Done that, cant see later Aussie Clubman stuff there though.
PostPosted: Sun Jul 01, 2007 5:54 pm
try this
http://www.mgb-stuff.org.uk/wiper4.htm
PostPosted: Sun Jul 01, 2007 6:05 pm
Sorry I can't help you d1ck0, had mine done by an autolec..
PostPosted: Sun Jul 01, 2007 6:17 pm
alsminik wrote:
Not the same unfortunately. This site says The rocker/toggle switches have pins 1 3 5 and 7 connected together internally. In the off position contacts 1 2 (park brown/light-green) 5 and 6 (slow red/light-green) are connected together. In the slow position contacts 3 4 (12v green) 5 and 6 (red/light-green) are connected together and in the fast position contacts 3 4 (12v green) 7 and 8 (blue/light-green) are connected together.
On a Clubman rocker switch there are pins 1,2,4,and 5. In the off position pins 4 and 5 are bridged. In low speed position its 2 & 1 that are bridged and in hogh speed its 2 & 4.
Thanks anyway.
Dicko.
PostPosted: Sun Jul 01, 2007 8:04 pm
When did you get your disc from Wombat? If in the earlier batch, you are quite right, it can't help you. I copied all the Australian supplement (including your required wiring diagram) and passed it on to Wombat for inclusion on any future requests for discs. If you need a copy PM me with some address details and I will post a copy of the Australian Supplement.
David
PostPosted: Tue Jul 03, 2007 4:47 pm
Got it sorted, bought a Leyland Gen Workshop Manual off Ebay.
Pin outs are as follows:
Pin 1 - Black/Green
Pin 2 - Black
Pin 4 - Red/Light Green
Pin 5 - Blue/Light Green
Dicko. :lol:
Users browsing this forum: stewartp, watsupskip and 79 guests
