It is currently Wed Aug 13, 2025 1:33 am
PostPosted: Mon Jul 02, 2007 7:32 pm
i foung these metro turbo 4 pot caliper brakes on ebay and was wondering if there a good buy or not wat are your opinoins.
cheers dan
http://cgi.ebay.com.au/mini-metro-turbo-4-spot-brakes-for-reconditioning_W0QQitemZ270136429138QQihZ017QQcategoryZ32072QQrdZ1QQcmdZViewItem
Cheers Dan
PostPosted: Mon Jul 02, 2007 7:36 pm
Only if you can re-condition them, and get driveshafts for less than what a set of ready to go ones cost.
No more Minis!......For now.
PostPosted: Mon Jul 02, 2007 7:47 pm
how much do you think it will cost to recondition them
Cheers Dan
PostPosted: Mon Jul 02, 2007 11:20 pm
it would cost you a heap to recondition them, I would say $300 + (cheaper if you did them yourself)
have you looked at getting a set of honda or camira brakes fitted? cheaper and easyer to get parts.
just my 2 cents.
PostPosted: Tue Jul 03, 2007 8:14 am
i wanted to go the metro turbo disks cause they have 4 pot calipers and they are good brakes and are easy to fit with the other types of brake upgrades you can get you have to get everything machined or custom made.
Cheers Dan
PostPosted: Tue Jul 03, 2007 8:16 am
with the drive shafts could you just use the cooper/s disk brake drive shafts
Cheers Dan
PostPosted: Tue Jul 03, 2007 8:26 am
I heard u need differnt lower arms to fit them..
how much are a set of cooper/s disk brake drive shafts?
PostPosted: Tue Jul 03, 2007 8:32 am
i don't konw how much a set a drive shafts are worh can't amagine them being to exspensive.
i've never heard of you having to change the lower arms befor.
Cheers Dan
PostPosted: Tue Jul 03, 2007 9:36 am
ah ok
thats just what i heard, ill find out for ya!
PostPosted: Tue Jul 03, 2007 9:54 am
yeah that would be good
Cheers Dan
PostPosted: Tue Jul 03, 2007 12:11 pm
depending on what needs to be reco'd you'd be looking more around $500-$600 mark.
PostPosted: Tue Jul 03, 2007 12:57 pm
damn thats heaps! get a set over from the uk!
just rang james, and he said you usaually have to change the lower arms. you can pick up adjustable lower arms off ebay for around $200.
can anyone else shed some light on this?
PostPosted: Tue Jul 03, 2007 1:04 pm
and if you don't already have adjustable steering arms, you'll need them with the metro hubs
PostPosted: Tue Jul 03, 2007 1:06 pm
Plus metro hubs have a different geomety, you WILL need adjustable lower arms and tie rods to make the geometry set right.
I say go for a set of cooper s discs!
Matt
PostPosted: Tue Jul 03, 2007 1:13 pm
I have a set of these I haven't fitted yet. Karcraft told me the early metro Turbo brakes had the same size ball joint shafts as the Aus Mini. The later ones were had bigger ball joints but the early ones are interchangeable (and are available). They are sealed units unlike Aussie Mini ball joints.
As for drive shafts, I can't see any difference between drum and disc brake shafts. The CV's are different. Pretty sure the drum brake drive shafts fit into the disc brake CV's. Anyone know for sure?
Pete
Users browsing this forum: No registered users and 250 guests
