It is currently Wed Jul 30, 2025 2:21 am
PostPosted: Fri Jun 29, 2007 10:35 pm
Finally getting the engine back together but i've got some new parts, i'm stuck on the following items:
How do you wire up the lucas electric distributor with the ignition module attached - theres 3no. terminals which ones goes to the coil etc?
Also do you need a special coil for that distributor or will the one that works with a points dizzy work?
is there a spacer between the block and the spin on oil filter, the holes dont line up exactly but there is a chamber that would let the oil through?
i also got a lucas alternator with the regulator attached theres also 3 terminals what goes where, as theres no description on the body? its a LRA100
any help would be great
:D
its not lost, i just cant find it.
