distributor lucas + others https://www.ausmini.com/forums/viewtopic.php?f=2&t=33401 |
Author: | where i put that [ Fri Jun 29, 2007 10:35 pm ] |
Post subject: | distributor lucas + others |
Finally getting the engine back together but i've got some new parts, i'm stuck on the following items: How do you wire up the lucas electric distributor with the ignition module attached - theres 3no. terminals which ones goes to the coil etc? Also do you need a special coil for that distributor or will the one that works with a points dizzy work? is there a spacer between the block and the spin on oil filter, the holes dont line up exactly but there is a chamber that would let the oil through? i also got a lucas alternator with the regulator attached theres also 3 terminals what goes where, as theres no description on the body? its a LRA100 any help would be great ![]() |
