Hydro & dry trailing arms - difference?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=33407 |
Author: | BrickNut [ Sat Jun 30, 2007 9:51 am ] |
Post subject: | Hydro & dry trailing arms - difference?? |
Hi all, just wondering what the difference between dry and hydro rear trailing arms. I know the mount for the shock and helper spring are different. Could i over come this with making a new shock mount/pin as i want to use hydro arms in a dry subframe? Cheers and happy mini-ing.... |
Author: | drmini in aust [ Sat Jun 30, 2007 10:46 am ] |
The leverage ratio is a bit different to a dry one. Some people say they won't work, but Steve (justminis) in Cairns says yes they do, with Hi-Los. You can drill & tap the end of the stub shaft to 3/8 UNF and use a Grade 8 bolt to mount the shock, no problem. ![]() |
