It is currently Tue Jul 22, 2025 9:02 am
PostPosted: Fri Jun 29, 2007 12:52 pm
How wide, long and heavy is a mini.
(I'm away from the car right now however need to make arrangement to transport the car in the next week)
PostPosted: Fri Jun 29, 2007 12:56 pm
4 Feet wide - 10 feet long - wt depends on model
David L
PostPosted: Fri Jun 29, 2007 1:17 pm
http://www.ausmini.com/forums/viewtopic ... sions+mini
PostPosted: Fri Jun 29, 2007 2:13 pm
Weight does depend on model - early ones start at around 620kg, Rovers finished just over 700kg. :) That's the manufacturer's quoted complete weights, anyway. If you're using a car transport company, it won't be any cheaper than moving a Statesman... :( But, given what you're asking, I suspect you may be moving it another way - in a shipping container or similar, where it will make a difference. :)
PostPosted: Sat Jun 30, 2007 9:24 pm
it will fit on a 2 wheel drive hilux, (been there and done it, moved it 650km that way and did it easy)
PostPosted: Sun Jul 01, 2007 12:22 pm
Width could be affected if you have 13 x 7 inch wheels or large flares.
4 feet also doesn't count mirrors.
:D
PostPosted: Sun Jul 01, 2007 12:32 pm
Don't forget clubbies are longer - 6 inches I think.
KB
PostPosted: Sun Jul 01, 2007 12:38 pm
I thought it was only two? :D
PostPosted: Sun Jul 01, 2007 4:16 pm
six inches sounds a lot , i thought they were the same just different shape, if they are longer id say it would be two
