Rear wheel bearing torque
https://www.ausmini.com/forums/viewtopic.php?f=2&t=33414
Author:  tsgwon [ Sat Jun 30, 2007 4:10 pm ]
Post subject:  Rear wheel bearing torque
I've just replaced the rear wheel bearings on one side of my machine.
My Haynes manual says the retaining nut torque should be 81Nm / 60lbft, but that feels REALLY tight. Is that the right torque???
The bearings I found when I dismantled the hub were ball rollers with a spacer between.
The bearing kit I have is just two taper rollers with no spacer, but the inner races are extended to take up the gap the spacer filled before.
Am I doing something wrong?
Author:  drmini in aust [ Sat Jun 30, 2007 4:30 pm ]
yes the torque is correct.
The tapered rollers when assembled in an unworn hub have about .001" preload, they should feel a little tight when torqued up to spec, but not jerky when turned by hand. :wink:
Author:  Harley [ Sat Jun 30, 2007 6:34 pm ]
And as a side note, a lot of torque wrenches dont work backwards (left hand thread), so don't overtighten it! :D
Author:  mini-dunger [ Sun Jul 01, 2007 2:37 am ]
Post subject:  wrench
I had the wrench problem yesterday. Its weird its got a left and right switch but doesnt click.I just tightened it up then backed it of until it would move at roughly the same time as it clicked
Author:  tsgwon [ Sun Jul 01, 2007 1:35 pm ]
Cool. Thanks for that chaps.
The hub does spin smoothly, but it seemed too tight for a bearing. It'll run in, I guess.
Regards
Jamie
