Mongrel size heads on brake backing plate to swivel hub https://www.ausmini.com/forums/viewtopic.php?f=2&t=3342 |
Author: | mini_van_1970 [ Wed Dec 08, 2004 5:20 pm ] |
Post subject: | Mongrel size heads on brake backing plate to swivel hub |
We've tried 9/32", 5/16" 8mm 9mm.... but nothing is exactly right for the heads of the bolts holding the brake backing plate to the swivel hub. HELP!....is this a mongrel size or what?.... Does anyone know what it should be?....or is it time for the gas axe? Pat |
Author: | drmini in aust [ Wed Dec 08, 2004 6:32 pm ] |
They are not metric- they are 3/8" A/F, from memory. ![]() May have been butchered in the past. ![]() If fitting Honda discs I'd get some 5/16" UNF x 3/4" setscrews, or Unbrako cap heads.. ![]() |
Author: | mini_van_1970 [ Thu Dec 09, 2004 10:49 pm ] |
Knew they wouldn't be mickrick, but nothing in AF would fit, ended up welding a bigger 1/2" nut to the one we couldn't get off. POP. love migs! The other side was 5/16" and come out without a problem ![]() Pat |
Author: | gafmo [ Thu Dec 09, 2004 10:55 pm ] |
Found the answer in your own back yard Grasshopper ![]() ![]() |
Author: | Wolfman [ Fri Dec 10, 2004 7:06 am ] |
mini_van_1970 wrote: Knew they wouldn't be mickrick, but nothing in AF would fit, ended up welding a bigger 1/2" nut to the one we couldn't get off. POP. love migs!
The other side was 5/16" and come out without a problem ![]() Pat I think all minis should come with a mig ![]() |
Author: | gafmo [ Fri Dec 10, 2004 7:16 am ] |
PM sent Pat...hope it's understandable ![]() |
