It is currently Sat Jul 26, 2025 11:01 am
 Post subject: Help - Clutch Adjustment
PostPosted: Sat Jun 30, 2007 10:17 pm
Hi All,
today I finished putting the motor in and connected it all up and it started first time
however
I have an issue with the clutch.
I can not put it into gear when the car is started.
I then tested by putting it into gear with the motor off, pressing the clutch pedal in and turning the enginer over to ensure the gearbox was engaging which it was and the car jumped forward.
Basically my problem is pressing the clutch pedal in does not do what it should be doing (ie nothing even though the master cylinder is moving as it should be upon visual inspection)
How do I adjust the clutch to do what it should be doing when the pedal is pressed down (ie disengage the clutch)?
thanks
white_mini_man
PostPosted: Sat Jun 30, 2007 11:13 pm
Resident Test Pilot
Bleed the clutch. One man job. If you get a bottlewith a hose through the lid (plastic coke bottle) you can sit it up where you can see it from inside the car and pump the clutch till you have a good stream of fluid squirting into the bottle.
If it continues to deteriorate then slave cylinder then master cylinder
PostPosted: Sat Jun 30, 2007 11:45 pm
NAV-MAN
Are all your bits new? New clutch? Master cyl? Slave cyl? Hose? Arm?
A quick check is remove the return spring on the clutch arm and pull it away from the motor the same way the slave cyl pushes it until it stops. If you have more than a few thou clearence between the arm and the adjusting bolt wind it out until you have a few thou clearence.
Re-attach the spring and give that a go. If still not working then it is elsewhere.
PostPosted: Sun Jul 01, 2007 12:29 am
same thing happened to me matt850 is 100% spot on thats what i had to do, redone the slave, then master
PostPosted: Sun Jul 01, 2007 8:19 pm
Thanks for your replies.
Today I rechecked & re-bled the system and now the clutch works beautifully....
3 weeks till rego time - its amazing how fast the clock turns when working to a deadline.
white_mini_man
PostPosted: Sun Jul 01, 2007 11:42 pm
NAV-MAN
Good to hear it was something simple.
PostPosted: Sun Jul 01, 2007 11:57 pm
and cheap! not another cost you need right now!
i had a similar problem, all my gears were doing were crunching. bled it and after that it was beautiful :D
78 Leyland Mini - Prince
Users browsing this forum: minimanic and 87 guests
