mk1 's' motor question https://www.ausmini.com/forums/viewtopic.php?f=2&t=33471 |
Author: | suffolk [ Mon Jul 02, 2007 10:13 am ] |
Post subject: | mk1 's' motor question |
Done a few searches on here couldn't find anything so,,Does anyone know the casting number on 1275 mk1 cooper s block?? And what part number would be on the main bearing caps .eg. AEG??? cheers |
Author: | wild_willy [ Mon Jul 02, 2007 11:38 am ] |
Mk 1 "S" block part number AEG312. Main bearing caps - no cast part No. But should have stamped 4 digit number that corresponds to the number stamped on the block (generally on the front of the block next to the water pump). |
Author: | sports850 [ Mon Jul 02, 2007 11:47 am ] |
Is this still the motor you were asking about before that's an unknown quantity , does it have caps with it ? The caps are matched to the block and other caps will require tunnel boring to match which is an extra expense if not there , something to keep in mind . |
Author: | drmini in aust [ Mon Jul 02, 2007 11:51 am ] |
Pretty sure all S blocks Mk1 and 2 have that same casting number on. All or most Mk1s were thin flange though I think. Thick flange block is more rigid. |
Author: | suffolk [ Mon Jul 02, 2007 11:51 am ] |
No i'm off to have a look at another block on wednesday,,,he reckons its a thick flanged with 9fsay,, which i don't think exists,,,bit of luck it might be a mk2 with mk1 restamp on it, I know a thick flange is about 15mm ,,,How thick would a thin flange be? |
Author: | drmini in aust [ Mon Jul 02, 2007 11:53 am ] |
about 6mm give or take. ![]() |
Author: | suffolk [ Mon Jul 02, 2007 11:56 am ] |
Thanks alot people, very helpful,,now i know what to look for....cheers |
Author: | suffolk [ Mon Jul 02, 2007 12:01 pm ] |
I just thought i'd add mr vizards book says thin flanged blocks can flex and cause oil leaks, that would have to be a pretty powerfull motor wouldn't it? Does putting the bigger bolts in the thin flange help this...anyone had this problem or is it bit of a myth... |
Author: | drmini in aust [ Mon Jul 02, 2007 1:49 pm ] |
I've had a couple of Mk1 S thin flanged road motors, the 1st had standard 1/4" bolts and the 2nd had 5/16". Neither leaked oilz. I think it matters more on competition motors. ![]() |
Author: | wild_willy [ Mon Jul 02, 2007 4:33 pm ] |
Used thin flanged Mk1 blocks in my J car. Never had any dramas with oil leaks except when a cam follower let go at 8000rpm. Punched holes in front and back of block - oo ah!!!! |
Author: | suffolk [ Mon Jul 02, 2007 4:50 pm ] |
ouch!! that would of hurt the poor girl pretty bad ![]() |
Author: | AJ [ Mon Jul 02, 2007 7:45 pm ] |
AEG 312 is the Mk1 casting number |
