helper springs help! https://www.ausmini.com/forums/viewtopic.php?f=2&t=33477 |
Author: | AEG163job [ Mon Jul 02, 2007 12:59 pm ] |
Post subject: | helper springs help! |
Guys, I have two sets of these, one has orange bands near the bottom eyelets, the others nothing. Does anyone know if there are different sets for different cars ie deluxes vs K's vs Clubbies vs Coopers? Thanks in anticipation of any assistance which will be gratefully received..................... ![]() |
Author: | Morris 1100 [ Mon Jul 02, 2007 1:02 pm ] |
There are different ones. I know of two different types, early and late. If you lay them side by side they look totally different. |
Author: | Anto [ Mon Jul 02, 2007 1:03 pm ] |
Is one set off a car with a dodgy orange paint job? ![]() |
Author: | CPOCSM [ Mon Jul 02, 2007 1:14 pm ] |
Your poo agitating Pete again Anto??? I thought they were all the same - they make good door returns too... Hooroo |
Author: | AEG163job [ Mon Jul 02, 2007 1:21 pm ] |
I should have been more precise - plastic orange bands. Also, I have struts of slightly different lengths (strut/tube, hydrolastic, rear, for the use of). The plot thickens ![]() |
Author: | drmini in aust [ Mon Jul 02, 2007 1:30 pm ] |
The orange ones were they later stronger ones. ![]() re the struts yes 2 lengths but I dunno which was which now. |
Author: | AEG163job [ Mon Jul 02, 2007 2:01 pm ] |
Thanks Doc. Seems logical the stronger springs would be more suited to the "S" models and the shorter struts the same, for a lower ride height. |
Author: | drmini in aust [ Mon Jul 02, 2007 2:06 pm ] |
The later stronger springs and shorter struts were fitted to all hydros from 1968 on, according to Vizard. ![]() |
Author: | 9YaTaH [ Mon Jul 02, 2007 2:59 pm ] |
Post subject: | Q without notice |
Is this all about trying to fix the droopy swing arm Pete ![]() |
Author: | AEG163job [ Mon Jul 02, 2007 4:15 pm ] |
Partly Mick. I found out that I had two differing length struts on that subbie, not realising they came in two sizes. I also noticed I had different types of springs. All off various cars I have broken up over the years without recording which came off what. ![]() |
Author: | 9YaTaH [ Mon Jul 02, 2007 4:25 pm ] |
Post subject: | Springs |
AEG163job wrote: Partly Mick. I found out that I had two differing length struts on that subbie, not realising they came in two sizes. I also noticed I had different types of springs. All off various cars I have broken up over the years without recording which came off what.
![]() OK....well with springs, if it is not immediately apparent which one is the stronger.....weeeeellllll....you could attach a decent weight to each one in turn and measure their excursion against a ruler....obliviously ![]() ![]() |
Author: | drmini in aust [ Mon Jul 02, 2007 7:15 pm ] |
Vizard also suggests in HTMYM that they can/should be shortened by 3/8". ![]() |
