Driveshafts https://www.ausmini.com/forums/viewtopic.php?f=2&t=33493 |
Author: | white_mini_man [ Mon Jul 02, 2007 8:28 pm ] |
Post subject: | Driveshafts |
I thought the drive shafts between drum & disc are the same. see this ad http://cgi.ebay.com.au/Mini-Morris-1275 ... dZViewItem[url][/url] |
Author: | helen6521 [ Tue Jul 03, 2007 7:30 pm ] |
Post subject: | drive shafts |
they are the same put disc brakes on my mini used drum shafts you only change flange |
Author: | d1ck0 [ Tue Jul 03, 2007 7:43 pm ] |
Post subject: | Re: drive shafts |
helen6521 wrote: they are the same put disc brakes on my mini used drum shafts you only change flange
When I converted my original '78 Clubman from Drums to disk, I had to use the Disk Brake CV Joints. They were larger on the splines etc. Used the Clubman shafts with inner Pot Joints etc, and used Disk Brake outer CV's. |
Author: | 73GT [ Wed Jul 04, 2007 7:44 am ] |
i thought the drum brake drive shafts were slightly longer, but splines the same as disc items. But you can get away with not worrying about it? |
