It is currently Wed Aug 13, 2025 2:41 pm
PostPosted: Mon Jul 02, 2007 10:47 pm
http://7faq.com/owbase/ow.asp?SurfaceHa ... OfSteel#h5
PostPosted: Tue Jul 03, 2007 9:24 am
It is interesting that once a crank has been ground any benefit of the hard surface giving good wear resistance will be lost. The fatigue improvement that takes place in the journal webs will also be lost.
Having a component re-nitrided is quite difficult as a 'white layer' is produced during nitriding and this MUST be removed before use. It is normal to remove this white layer by grinding and an allowance must be left on the component before surface treatment. It could be done but it would need thinking about carefully as you may need to partially re-grind, nitride, then finish grind. As grinding not only removes the 'white layer' but also reduces surface hardness allowances need to be worked out carefully.
So if I have a cooper s crank (EN40B, Nitrided) that is ground 20 thou under, the hardening will be lost?
So I have to get it re nitrided?
Can it be tuftrided instead?
Basically, how far can they be ground before the hardening is lost?
PostPosted: Tue Jul 03, 2007 10:16 am
May be a engine reconditioner could answer your questions,,someone on here is bound to know....Just think of all the cranks out there that have been reground,,ive seen a few and there didn't seem to be a problem with them,,I think 0.20 might be safe any more and i think they need treating...but i'm not sure on this.. it will be interesting what people on here say about it.....
PostPosted: Tue Jul 03, 2007 10:49 am
Yeh, I thought I had heard that 20 thou was safe, any further needed redoing.
Anyone actually KNOW this for sure, or if there is a test that can be done to see if it is still alright?
matt
PostPosted: Tue Jul 03, 2007 6:33 pm
Ive got a crank that was ground 60thou the bearings are huge!! the crank is not being used though... 8)
68 Mini
70 Moke
 Post subject: Nitriding
PostPosted: Tue Jul 03, 2007 7:16 pm
I have had many cranks nitrided and I was always told the nitriding itself is only about .010" or so when crank is finishes. Usually when they do the Grind they have to leave the crank still unfinished as they always have to re grind them after the process because of distortions and to get a good finish. If a crank is re ground after that it should be Nitrided again.
"Let us remove your "SHORTS"
PostPosted: Tue Jul 03, 2007 7:20 pm
I've been told by various people that BMC in the 60s managed to get the nitriding on the EN40B S cranks lots deeper than .010".
My spare Mk1 S crank is now -.030" on the mains and -.020" on the rod journals, the guy who regrinds GR's cranks (Spiro, at St George Crankshafts) says it is still hard as hell. 8) :D
I've also been told by various engine reco people that nitriding EN16 cranks to `harden' them is a waste of time- that article (and others) bears this out. It really only works on nitriding steels, eg EN40B or other steels containing aluminium or vanadium.
Tufftriding is very hard to get done in Oz now, apparently the EPA jumped on all the heat treaters that were doing it, for health and safety reasons.
it is a hot arsenic salt bath process.
There is supposed to be one place in Melbourne that still does it, for the aero industry.
PostPosted: Wed Jul 04, 2007 9:06 am
So it can be tested to check if the hardness is still there? Spiro can do this? Can he get them re-nitrided etc if needed?
matt
PostPosted: Wed Jul 04, 2007 7:33 pm
Whether crank is still hard on not is apparent during the grinding process.
Yes I'm sure if you want it re-nitrided, Spiro can arrange it.
Beware though, cranks have been known to bend after re-nitriding. One ausmini member had to get the crank changed in his reconditioned motor because of this.
:wink:
<edit> typo
Last edited by drmini in aust on Wed Jul 04, 2007 8:19 pm, edited 1 time in total.
PostPosted: Wed Jul 04, 2007 8:15 pm
I wont be touching mine since Spiro said it was perfect 8)
PostPosted: Wed Jul 04, 2007 11:13 pm
:wink:
<edit> typo
The crank i have is already reground to 20 thou under. Can it be checked without more grinding?
Users browsing this forum: No registered users and 328 guests
