[quote="Irish Yobbo"]First thing's first - what type of brake system do you have? From what you've said, I'd presume it's all drums with twin-leading shoes at the front? What type of master cylinder do you have?
A good thing to check is to put some vise grips on the hoses, and check the pedal. Is it still spongy? If it is, it's master cylinder/bias valve side, if not, it's wheel side.
I had an issue with the brake pedal dropping right to the floor, and it turned out to be my PDWA valve, found on later aussie cars. Your bias valve can be the issue. It can also be an issue with old hoses expanding.[/quote]
As mentioned, all wheel drum. Twin leading shoe front end. I replaced the brake master cylinder with the plastic previous type available from mini parts suppliers. I've no PDWA valve? only the brake bias valve found on earlier cars...
_________________ 1970 mini k1100
