what's this su?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=33503
Author:  cush [ Tue Jul 03, 2007 12:17 am ]
Post subject:  what's this su?
is this a right hander 1 1/4 inch ?
Author:  Matt68 [ Tue Jul 03, 2007 8:55 am ]
Looks like an ordinary 1.25" SU to me. What are the cast numbers on the side of the carb body? Should be AUC1341 or something similar.
matt
Author:  cush [ Tue Jul 03, 2007 10:38 am ]
does it just have the quarter turn bit bolted on to the wrong end?
Author:  Matt68 [ Tue Jul 03, 2007 10:44 am ]
Um....
Not sure what you mean.
Author:  cush [ Tue Jul 03, 2007 12:21 pm ]
the bit that attaches the carb to the air cleaner... it does a 45* turn.. :)
i don't know why i said quarter... :P
the float seems to be on the opposite side to mine..
Author:  Matt68 [ Tue Jul 03, 2007 1:42 pm ]
You have a HS4 then right? They have the float bowl on the other side.
The pic is of a standard 1.25" HS2 SU carb as far as I can tell. The air horn (yep, that is what it's called :roll: ) which attaches it to an air filter is standard to most of these, allows the air cleaner to sit horizontal. Terrible for air flow tho!
It might be one of a pair, depending on the casting number. Have a look for it, on the side of the body of the carb.
The one you want is AUC1341 i think.
But even if it is this type, it isn't the one that you can build a set of twins from.
Matt
Author:  poeee [ Tue Jul 03, 2007 2:07 pm ]
That is what always confuses me. I can never remember which is the non mirrored HS2, as the non mirrored HS4 is on the other side! :lol:
