It is currently Sat Aug 02, 2025 10:06 am
 Post subject: alternator
PostPosted: Fri Jul 06, 2007 8:04 am
Just brought a 17ACR alternator, usual thing thou no wiring diagrams on the box and nothing on the regulator, and cannot find anything in manuals etc.
Does anyone know of the 3 terminals which is which and where they go?
its not lost, i just cant find it.
PostPosted: Fri Jul 06, 2007 8:36 am
i think you will find it in the how tos section :wink:
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
 Post subject: 17 ACR
PostPosted: Fri Jul 06, 2007 12:46 pm
On a 17 ACR Alternator you will find 2 large spade terminals and one small one. The two large ones are Battery positive (B+) and the small one is the warning lamp wire (D+). Make sure it is the correct Internally regulated Alternator as some externallly regulated ones had one of the big terminals a NEGATIVE. These were the Alternators with half a plastic cap on the back. Also check the wiring in the car make sure it is the same system. And please don't let the smoke out of the wiring otherwise nothing will work.
"Let us remove your "SHORTS"
