wheel nut just spins, wheel stuck on, flat tyre.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=33617
Author:  -=MiniMafia=- [ Fri Jul 06, 2007 8:00 pm ]
Post subject:  wheel nut just spins, wheel stuck on, flat tyre.
hey all,
three out of four nuts come off the rear left wheel, one is stuck on, it just spins. I have had no luck getting it off. what now?
oh yeah, and the tyre wont hold any air, so it has to come off lol!
Author:  d1ck0 [ Fri Jul 06, 2007 8:04 pm ]
Sometimes you can get them off with 2 people. 1 to apply outwards pulling pressue on the wheel whilst you undo the nut. An angle griner used carefully can help too.
What type of wheel and nut are we talking about?
Dicko.
Author:  Mick [ Fri Jul 06, 2007 8:18 pm ]
Yep, exactly what he said ^^ if you can pull on the wheel as you turn the nut it will eventually bite on the remaining threads and eventually come off.
Seeing as though the stud (or nut) is threaded, if it doesn't come off after all this, then you may have to go it with an angle grinder carefully. That ought to teach it a lesson it won't forget..
Author:  drmini in aust [ Fri Jul 06, 2007 8:23 pm ]
If it's one of those domed Clubby nuts I bet it's stripped. they made these from brass, ffs.
Angle grind 1 side until you just start to see the stud threads. Then hit it with 2 BFHs, 1 from each side. :lol: :wink:
Author:  -=MiniMafia=- [ Fri Jul 06, 2007 8:56 pm ]
hey guys
this is the car, those are the wheels. i have tried pulling the wheel and turning the nut, no luck.
Author:  willy [ Fri Jul 06, 2007 8:57 pm ]
Tap into the end of the nut, screw a bolt in there and pull out on the bolt. If you pull hard enough it'll come out easy peasy.
Bit of rooting around but you'll get there.
Author:  d1ck0 [ Fri Jul 06, 2007 9:00 pm ]
What ever you do I can see you'll want to do it carefully. Nice lookng set of wheels.
Dicko.
Author:  -=MiniMafia=- [ Fri Jul 06, 2007 9:06 pm ]
lol im taking the wheels off, i hate them. im putting a set of stock rims on. (and welding the front gaurds back)
ill put the wheels aside for a project, later in life.
thanks guys, i should have it off by tomorrow ;)
Author:  drmini in aust [ Fri Jul 06, 2007 10:15 pm ]
Those big wheels (would) look good, Josh. On a Moke.... :lol: 8)
Author:  -=MiniMafia=- [ Fri Jul 06, 2007 10:19 pm ]
lol i know, i didnt buy em :P
Author:  NAV [ Fri Jul 06, 2007 11:50 pm ]
Just a thought.
I know you can't see it but i wonder if it's the stud that is actually turning?
Ahh the joys of owning mini's
Author:  lil-ute [ Sat Jul 07, 2007 7:54 am ]
i think they look good on a moke as well
Author:  drmini in aust [ Sat Jul 07, 2007 8:04 am ]
Looking good Al, what size tyres?? :P
Author:  lil-ute [ Sat Jul 07, 2007 9:49 am ]
tyre size is 185 x 65 x 13 on 13 x 6 rims
