Leaking Boot https://www.ausmini.com/forums/viewtopic.php?f=2&t=3369 |
Author: | 1380 yellow devil [ Thu Dec 09, 2004 4:18 pm ] |
Post subject: | Leaking Boot |
What is the best rubber seal That al u good fellows have used to seal the boot to stop any Water getting. Mine has the orginal rubber but it is totally stuffed. ![]() |
Author: | drmini in aust [ Thu Dec 09, 2004 9:02 pm ] |
I reckon you can't beat the original MK1 type sponge seal. I got mine in from MiniSport 10 years ago, it's still OK.. ![]() |
Author: | 1380 yellow devil [ Fri Dec 10, 2004 10:33 am ] |
Are they a pain to fit with the orginal clps that hold them on. By The way mine is th orginal and over 30 years old |
Author: | Wolfman [ Fri Dec 10, 2004 1:56 pm ] |
Yes they are a pain, throw away the clips and just quick grip it ![]() |
Author: | spathi [ Fri Dec 10, 2004 2:20 pm ] |
I used the clips and didnt find it to hard, once you know how they go on. In saying that I wouldn't bother unless you are looking to do a completely original resto. They are fiddly to put on and I question the strength of the clips and how well they hold the rubber on. More trouble then they are worth. If i have any problems I'll be using kwik grip instead of buying more clips. Id go the kwik grip, and as the clips cost, what?, about $1 each its cheaper to buy a litre of kwik grip (which is WAY more then you need just for the rubber, but will last you for ages). |
Author: | dewey [ Fri Dec 10, 2004 4:14 pm ] |
I think my petrol cap seal must be leaking... the rain has been torrential around here for the last week. It's all bad! My boot had a truck load of water in it. Not happy about that. I had a thread running about the boot seal about 2 weeks ago: http://www.tziworld.com/ausmini/viewtopic.php?t=2974 Since we're talking about seals, I'll tack on a question here: I did my front quarter seals. I've left the door cards off to see how it goes in the rain and I'm getting a lot of water coming into the door from the quarter vent. The water doesn't actually come into the car but it sprays in above the winder mechanism and cause I can get my hand in there I can feel it coming off the bolt that the vent pivots on. Is this meant to happen or have I stuffed up the fitment of the seal? dewey |
Author: | 1380 yellow devil [ Sat Dec 11, 2004 10:51 am ] |
Thanks people's I will glue in my new on But I have seen some people use a door rubber and stick it around the boot on the body not the boot lid and Now No glue and No leakys |
