It is currently Wed Jul 16, 2025 3:13 pm
 Post subject: Leaking Boot
PostPosted: Thu Dec 09, 2004 4:18 pm
What is the best rubber seal That al u good fellows have used to seal the boot to stop any Water getting.
Mine has the orginal rubber but it is totally stuffed. :evil:
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Thu Dec 09, 2004 9:02 pm
I reckon you can't beat the original MK1 type sponge seal. I got mine in from MiniSport 10 years ago, it's still OK.. :wink:
PostPosted: Fri Dec 10, 2004 10:33 am
Are they a pain to fit with the orginal clps that hold them on.
By The way mine is th orginal and over 30 years old
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Dec 10, 2004 1:56 pm
Yes they are a pain, throw away the clips and just quick grip it :)
PostPosted: Fri Dec 10, 2004 2:20 pm
I used the clips and didnt find it to hard, once you know how they go on. In saying that I wouldn't bother unless you are looking to do a completely original resto. They are fiddly to put on and I question the strength of the clips and how well they hold the rubber on.
More trouble then they are worth. If i have any problems I'll be using kwik grip instead of buying more clips.
Id go the kwik grip, and as the clips cost, what?, about $1 each its cheaper to buy a litre of kwik grip (which is WAY more then you need just for the rubber, but will last you for ages).
'68 Morris Mini Matic (GF's)- complete!
'68 Morris Mini Deluxe - deciding on specs..
'63 Morris 850 - On the Shelf
Other various mini parts cars :)
PostPosted: Fri Dec 10, 2004 4:14 pm
I think my petrol cap seal must be leaking... the rain has been torrential around here for the last week. It's all bad! My boot had a truck load of water in it. Not happy about that.
I had a thread running about the boot seal about 2 weeks ago:
http://www.tziworld.com/ausmini/viewtopic.php?t=2974
Since we're talking about seals, I'll tack on a question here:
I did my front quarter seals. I've left the door cards off to see how it goes in the rain and I'm getting a lot of water coming into the door from the quarter vent. The water doesn't actually come into the car but it sprays in above the winder mechanism and cause I can get my hand in there I can feel it coming off the bolt that the vent pivots on. Is this meant to happen or have I stuffed up the fitment of the seal?
dewey
dwightgunning.com
PostPosted: Sat Dec 11, 2004 10:51 am
Thanks people's I will glue in my new on But I have seen some people use a door rubber and stick it around the boot on the body not the boot lid and Now No glue and No leakys
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
