rover mini info
https://www.ausmini.com/forums/viewtopic.php?f=2&t=33948
Author:  dove grey 64 [ Tue Jul 17, 2007 1:54 pm ]
Post subject:  rover mini info
recently got a halfcut from brickworx (cheers steve) and on the auto selector is has park,reverse,neutral,1,2,3 and drive.
are auto rovers 3 speed?
im planning on using a old school selector (with the 1,2,3,4) has anybody else done this?
also does anybody know what diff ratio a 97 efi auto rover should have?
Author:  Spaceboy [ Tue Jul 17, 2007 1:57 pm ]
4 speed.
Author:  cush [ Tue Jul 17, 2007 2:04 pm ]
hehe...yeah... d is your 4th gear.. :)
or you could put it in R for racing.. :P
Author:  boho [ Tue Jul 17, 2007 2:34 pm ]
:roll: :lol:
Author:  dove grey 64 [ Tue Jul 17, 2007 3:45 pm ]
ok so the auto in a old mini, had reverse, drive 1,2,3,4. true or false, if you left it in fourth and stopped it would stay in fourth, so when you went to take off in fourth (apart from slugging about it would burn out the auto trannie etc)
so whats the deal with the newer rover/metro type selector? where is the 4th gear selector?
Author:  Spaceboy [ Tue Jul 17, 2007 5:03 pm ]
well in the old minimatic i believe 4th is identical to drive
the owners manual goes into detail about how to drive the matic transmission.
Author:  doogie [ Tue Jul 17, 2007 5:28 pm ]
Post subject:  Re: rover mini info
I hope you have better luck with your auto than i had with mine, after they sit for a while the seals in the box go hard & they have trouble selecting gear, i had mine adjusted several times to improve it but it was never perfect.
Good luck with it
Doogie
Author:  dove grey 64 [ Tue Jul 17, 2007 6:32 pm ]
:shock: yeah i hope i have good luck with it aswell. the oil showing on the dipstick looks brandnew, hopefully that helps
Author:  bnicho [ Tue Jul 17, 2007 7:46 pm ]
Hi,
Early autos (Mini-Matic) have RN1234D. 80's ex UK/Japan Minis have RN123D. Somewhere around 1989 Park was added giving PRN123D.
If you put an auto in 1,2,3 (or 4 on an early car) it will stay in that gear, evn if you come to a stop. If you put it in D it will change automatically. Unfortunately you can't lock a later Auto (without the 4 position) in 4th.
It is possible to use the early RN1234D shifter on the PRN123D box, since it has the same number of shifter positions. Simply adjust by the book, change the labels for the shifter positions and it usually works! The only caveat is you may have to file the D position out a little at the bottom to allow enough throw to get into Drive. If you cant get fully into Drive it will take off in 3rd and be very sluggish!
Author:  dove grey 64 [ Tue Jul 17, 2007 8:34 pm ]
thanks bnicho, exactly the info i was after, have you done this yourself before?
Author:  bnicho [ Tue Jul 17, 2007 10:08 pm ]
No worries.
Yep, I transplanted a 1990 A+ 1275 Auto with Park into my Moke. Then engine came without a shifter, so I briefly used a Mini Matic one until I got the correct one (with Park) from Brickworx. I also know another couple of guys who are into Autos, so I leant a lot from them.
IMHO the Autobox is highly underrated. Sure you lose a bit of power at the wheels, but it's nice to be able stick it in D when you are just cruising or choose to manually shift for fun. :D
Author:  mad-mk1 [ Tue Jul 17, 2007 11:22 pm ]
put it in l for lay rubber
slightly of topic, has anyone seen a b+m megashifter in a mini? would be tad big but somethuing different?
Author:  dove grey 64 [ Wed Jul 18, 2007 8:21 am ]
the halfcut i have has a shifter (the later type metro'ish one), the old type selector looks heaps better though in my opinion.
sounds like a interesting moke, have you posted pics of it?
Author:  bnicho [ Wed Jul 18, 2007 9:52 am ]
Hi,
The Metro type shifter is teh one I have. I preferred the look of it to the early one. :)
Maybe a B&M shifter could be used, but I've never seen one with enough shift positions. All the ones I've seen have been PRND21 (three speed box) or PRNDL (two speed powerglide etc).
Some pics of my Moke at:
http://www.ausmini.com/forums/viewtopic.php?t=18069
Author:  supercharged 850 [ Thu Jul 19, 2007 3:11 am ]
Its just a matter of dressing up the original stick and housing to make it look like a B&M. Have planned this for my roadster many moons ago.....
