Clutch Master Cylinders. Tin vs Plastic https://www.ausmini.com/forums/viewtopic.php?f=2&t=33974 |
Author: | ziff [ Wed Jul 18, 2007 7:51 am ] |
Post subject: | Clutch Master Cylinders. Tin vs Plastic |
I'm pretty sure it's OK but want to confirm that the newer plastic type clutch master cylinders are interchangeable (without any mods) with the old tin type. I've done a search but haven't found the answer yet. Thanks. Ziff |
Author: | My_Mini_Rocks [ Wed Jul 18, 2007 9:49 am ] |
Post subject: | Master cylinder |
Fitted hundreds of the plastic ones with no problems (unless people fit the brake master around the wrong way)....lol ![]() Regards, Andrew |
Author: | slinkey inc [ Wed Jul 18, 2007 12:52 pm ] |
Yeah are fine. Only problem I found was the plastic extension tubes that I had before on my clutch didn't seal again. But since it's clutch, and you can now see through them to view the fluid level it's all ok. I would care bout the brake but I got a brand new Cooper S tin (taller than standard mini) type one for $120, I think that was cheap. |
Author: | ziff [ Wed Jul 18, 2007 4:14 pm ] |
Great. Thanks very much fella's. Ziff |
