Camber Kits - Just arrived :D https://www.ausmini.com/forums/viewtopic.php?f=2&t=34149 |
Author: | pristic [ Tue Jul 24, 2007 7:57 am ] |
Post subject: | Camber Kits - Just arrived :D |
Howdy Folks, Well, I just got my Camber Kit from the UK. Front AND Rear ... yippee!!:D Fitting it up this week hopefully and then getting alignment done. Ive heard with adjustable lower arms and a negative camber the pot joints can seperate... !! Anyone have any experience with this? Is it just a matter of making sure you use new circlips? Any tips or horror stories about fitting or running adjustable all round? Before people say 'Why' ... the answer is because I have 1/2 a degree positive on the right, 1/2 degree negative on left... 1mm toe OUT on the rear and its crabbing... so I got the whole shebang to sort her out nice! . Edit: Couple of people have also said throw in HiLo's while your at it.. to really set it up right... so I may just do dat ![]() Peter. |
Author: | slo_firo [ Tue Jul 24, 2007 8:20 am ] |
i got everything adjustable - havnt driven it too much as only just got it legal but so far so good!! handles excellent although the wheel alainment shop was a bit pissed as it took them ages to set up right just with the tie bars i used one standars bush and one hard bush cos i read in calvers articles it was better to do that as hard bushes on both sides stressed everything out, |
Author: | JC [ Tue Jul 24, 2007 10:19 am ] |
My tip - Take it to a mini suspension specialist to set up the geometry. And get Hi lo's. You might aswell get the ride height right first. And why is it crabbing? Is the shell bent or subframe not fitted properly? |
Author: | 9YaTaH [ Tue Jul 24, 2007 6:03 pm ] |
Post subject: | Check |
There is a case down here where a rear camber kit went out of adjustment...brand unknown. So maybe have a way of quickly checking the alignment every now and then after fitting. |
Author: | 1071 [ Tue Jul 24, 2007 6:19 pm ] |
Alignment always goes out. Rear camber must be the easiest measurement to check....all you need is an old carpenters level. Cheers, Ian |
Author: | justminis [ Tue Jul 24, 2007 7:33 pm ] |
Post subject: | Re: Camber Kits - Just arrived :D |
pristic wrote: Howdy Folks,
Ive heard with adjustable lower arms and a negative camber the pot joints can seperate... !! Anyone have any experience with this? Is it just a matter of making sure you use new circlips? Peter. I have run pot joints on my race car for over 7 years with (at times) 2.5 degrees negative camber without any problem. |
Author: | drmini in aust [ Tue Jul 24, 2007 7:34 pm ] |
Just fit 4 new wire clips, they are only 4 bux each or so. ![]() |
Author: | 9YaTaH [ Tue Jul 24, 2007 9:05 pm ] |
Post subject: | Toe |
1071 wrote: Alignment always goes out. Rear camber must be the easiest measurement to check....all you need is an old carpenters level.
Cheers, Ian Good idea...unfortunately, Ians rears had excessive toe in ![]() |
Author: | mattywood [ Tue Jul 24, 2007 10:49 pm ] |
what was the price to import? |
Author: | Mini Mad [ Tue Jul 24, 2007 11:28 pm ] |
I got these for the rear: Best ones - as Mick says some can go out of alignment but these have serated edges to lock them in ![]() |
