It is currently Thu Aug 14, 2025 11:39 am
PostPosted: Wed Jul 25, 2007 8:45 pm
hi, i'm woundering if i could glass bead blast my gearbox internals. i'm not sure if the glass will remove the heat treating on the gear. has anyone bead blasted there gears before.
PostPosted: Wed Jul 25, 2007 9:15 pm
why would you do the INternal of a Gear box :shock:
I could understand the out side thou :wink:
PostPosted: Wed Jul 25, 2007 9:50 pm
never heard of media blasting gearbox parts
PostPosted: Thu Jul 26, 2007 12:52 pm
Waste of time i would think?? or has the gerabox been outside in the weather?
PostPosted: Thu Jul 26, 2007 7:41 pm
If there is slight surface rust on the gears use some crc and a soft green kitchen scourer, if there is heavy rust then there is already more damage done than a bead blaster will ever do to them.
Michael N
PostPosted: Thu Jul 26, 2007 7:45 pm
Take it to a car wash that has a hot water engine wash and give it a good blast with the engine degrease cycle
David L
Users browsing this forum: Bing [Bot] and 262 guests
