Glass Bead blasting Gearbox Parts https://www.ausmini.com/forums/viewtopic.php?f=2&t=34207 |
Author: | volkmini [ Wed Jul 25, 2007 8:45 pm ] |
Post subject: | Glass Bead blasting Gearbox Parts |
hi, i'm woundering if i could glass bead blast my gearbox internals. i'm not sure if the glass will remove the heat treating on the gear. has anyone bead blasted there gears before. |
Author: | gafmo [ Wed Jul 25, 2007 9:15 pm ] |
why would you do the INternal of a Gear box ![]() I could understand the out side thou ![]() |
Author: | Spaceboy [ Wed Jul 25, 2007 9:50 pm ] |
never heard of media blasting gearbox parts |
Author: | minimetoy [ Thu Jul 26, 2007 12:52 pm ] |
Waste of time i would think?? or has the gerabox been outside in the weather? |
Author: | Clubbie74 [ Thu Jul 26, 2007 7:41 pm ] |
If there is slight surface rust on the gears use some crc and a soft green kitchen scourer, if there is heavy rust then there is already more damage done than a bead blaster will ever do to them. |
Author: | Wombat [ Thu Jul 26, 2007 7:45 pm ] |
Take it to a car wash that has a hot water engine wash and give it a good blast with the engine degrease cycle |
