It is currently Tue Aug 19, 2025 3:35 am
 Post subject: Rust around th seems
PostPosted: Thu Jul 26, 2007 9:37 am
Hi all,
As i begin my search for a suitble resto car, i have found that alot suffer rust along the seems, my question relate's to the size of this problem, most cars dont appear from the outside to be huge, but i imagine its a tough spot to work on it?
any thoughts, ideas, suggestions?
Rob
 Post subject: Seams
PostPosted: Thu Jul 26, 2007 6:50 pm
Well as we don't know where you are....if you are in the northern hemisphere it could be a major problem...but if you are in Australia then it usually is treatable.
You carefully remove the seam covers, they are brazed top and bottom and held on by clips and then you can see the extent of the problem.....
PostPosted: Thu Jul 26, 2007 10:03 pm
Remember, rust is like icebergs, only 1/7th is visible above the surface. Its never better than it looks!
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jul 27, 2007 10:08 am
Although... I had a few rust bubbles around the seams and fearing the worse I took the seam covers off (only held on by clips, no brazing) and took to the rust bubbles with a 3M wheel. It actually wasn't as bad as I feared and needed no welding
PostPosted: Fri Jul 27, 2007 7:25 pm
I find the seams themselves are seldom a problem, bad rust starts next to the seams... :x
patch time, unless you are spending more $$$ and replacing panels....
 Post subject: Seam Covers
PostPosted: Fri Jul 27, 2007 9:14 pm
Don't know where you are either Buddy :roll:
But anyway....has anyone else seen seam covers just clipped on then painted from the factory :?: I'd say this car has had new seam covers fitted at some time :idea: :D
Users browsing this forum: No registered users and 335 guests
