It is currently Tue Aug 19, 2025 1:15 pm
PostPosted: Fri Jul 27, 2007 5:07 pm
are they not designed to come apart from the seat ?
they lack the adjustment holes and wingnuts of all the other minis i've had.
i took to it with an angle grinder to get them off :(
also the bolt mounting points for the seat mounting brackets inside the box section are rooted, what should i do?
the brackets are welded on, after i grind them off, should i weld on a new set or can it be repaired somehow?
PostPosted: Fri Jul 27, 2007 5:13 pm
Put a photo up of whats there because yours should be the same as other mini's . Some really early ones had a slightly different setup but your's should be conventional . Someone may have done a dodgy at some stage ?
PostPosted: Fri Jul 27, 2007 5:14 pm
someones definitely done a dodgy :(
 Post subject: Was it welded on?
PostPosted: Fri Jul 27, 2007 5:24 pm
Too hard to see...but the seat part looks normal...looks like a hole in the end of the flat...
PostPosted: Fri Jul 27, 2007 5:27 pm
i bent it all out of shape taking the old seat out..
ignore the seat in the background its from something else..
PostPosted: Fri Jul 27, 2007 5:30 pm
compared to the brackets i'm used to which feature on the passenger side, also with rooted bolts
PostPosted: Fri Jul 27, 2007 5:31 pm
They look normalish , there should have been a bolt with a wing nut through the hole in the bracket and the hole in the seat leg . What was through there before you butchered it ?
PostPosted: Fri Jul 27, 2007 5:33 pm
well thats what im saying, there is no provision for a bolt and wingnut, the ones on the later ones are square so the nut doesnt turn, but this one had a sort of a pin which looked similar but had no wingnut, i have no idea how it was attached, as there was no way to remove it.
considering everything was buggered i wasnt worried about chopping it up.
PostPosted: Fri Jul 27, 2007 5:38 pm
The real early 850's had a different design, like this:
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jul 27, 2007 6:32 pm
Early ones (definitely UK; not sure about Oz versions) had the bracket rivetted to the seat. You removed the seat by undoing the two bolts that go into the crossmember.
Cheers, Ian
PostPosted: Fri Jul 27, 2007 6:37 pm
Just because there's no square doesn't mean you can't use the wing nut and bolt , they aren't very tight anyway(there's a limit to the force you can put on a wing nut) and most have wing nuts on a normal bolt so you can grip it with a spanner . The bracket looks like a normal 850 one , how was the seat fixed to the bracket ?
PostPosted: Fri Jul 27, 2007 6:48 pm
Cheers, Ian
yeah like that, but some idiot has broken the bolts
PostPosted: Fri Jul 27, 2007 7:18 pm
Most 850s here did not have the common 3 hole adjustable brackets. My passenger seat in HaHa is out of a `64 850. It was rivetted to the single hole brackets by the factory. :x
Mr Anglegrinder to the rescue, it now sits in the usual 3 hole brackets. :D
PostPosted: Fri Jul 27, 2007 7:24 pm
im pretty sure i have a set of them here somewhere!!!
if your interested ill dig them out,
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Jul 27, 2007 7:58 pm
tis okay, i have a set of the 3 hole ones otherwise i wouldnt have hacked into them with an angle grinder :)
Users browsing this forum: Bing [Bot] and 297 guests
