morris 850 seat mounting brackets https://www.ausmini.com/forums/viewtopic.php?f=2&t=34244 |
Page 1 of 2 |
Author: | Spaceboy [ Fri Jul 27, 2007 5:07 pm ] |
Post subject: | morris 850 seat mounting brackets |
are they not designed to come apart from the seat ? they lack the adjustment holes and wingnuts of all the other minis i've had. i took to it with an angle grinder to get them off ![]() also the bolt mounting points for the seat mounting brackets inside the box section are rooted, what should i do? the brackets are welded on, after i grind them off, should i weld on a new set or can it be repaired somehow? ![]() |
Author: | sports850 [ Fri Jul 27, 2007 5:13 pm ] |
Put a photo up of whats there because yours should be the same as other mini's . Some really early ones had a slightly different setup but your's should be conventional . Someone may have done a dodgy at some stage ? |
Author: | Spaceboy [ Fri Jul 27, 2007 5:14 pm ] |
someones definitely done a dodgy ![]() |
Author: | 9YaTaH [ Fri Jul 27, 2007 5:24 pm ] |
Post subject: | Was it welded on? |
Too hard to see...but the seat part looks normal...looks like a hole in the end of the flat... |
Author: | Spaceboy [ Fri Jul 27, 2007 5:27 pm ] |
![]() i bent it all out of shape taking the old seat out.. ignore the seat in the background its from something else.. |
Author: | Spaceboy [ Fri Jul 27, 2007 5:30 pm ] |
compared to the brackets i'm used to which feature on the passenger side, also with rooted bolts ![]() |
Author: | sports850 [ Fri Jul 27, 2007 5:31 pm ] |
They look normalish , there should have been a bolt with a wing nut through the hole in the bracket and the hole in the seat leg . What was through there before you butchered it ? |
Author: | Spaceboy [ Fri Jul 27, 2007 5:33 pm ] |
well thats what im saying, there is no provision for a bolt and wingnut, the ones on the later ones are square so the nut doesnt turn, but this one had a sort of a pin which looked similar but had no wingnut, i have no idea how it was attached, as there was no way to remove it. considering everything was buggered i wasnt worried about chopping it up. |
Author: | Timbo [ Fri Jul 27, 2007 5:38 pm ] |
The real early 850's had a different design, like this: ![]() Tim |
Author: | 1071 [ Fri Jul 27, 2007 6:32 pm ] |
Early ones (definitely UK; not sure about Oz versions) had the bracket rivetted to the seat. You removed the seat by undoing the two bolts that go into the crossmember. Cheers, Ian |
Author: | sports850 [ Fri Jul 27, 2007 6:37 pm ] |
Just because there's no square doesn't mean you can't use the wing nut and bolt , they aren't very tight anyway(there's a limit to the force you can put on a wing nut) and most have wing nuts on a normal bolt so you can grip it with a spanner . The bracket looks like a normal 850 one , how was the seat fixed to the bracket ? |
Author: | Spaceboy [ Fri Jul 27, 2007 6:48 pm ] |
1071 wrote: Early ones (definitely UK; not sure about Oz versions) had the bracket rivetted to the seat. You removed the seat by undoing the two bolts that go into the crossmember.
Cheers, Ian yeah like that, but some idiot has broken the bolts |
Author: | drmini in aust [ Fri Jul 27, 2007 7:18 pm ] |
Most 850s here did not have the common 3 hole adjustable brackets. My passenger seat in HaHa is out of a `64 850. It was rivetted to the single hole brackets by the factory. ![]() Mr Anglegrinder to the rescue, it now sits in the usual 3 hole brackets. ![]() |
Author: | mad-mk1 [ Fri Jul 27, 2007 7:24 pm ] |
im pretty sure i have a set of them here somewhere!!! if your interested ill dig them out, |
Author: | Spaceboy [ Fri Jul 27, 2007 7:58 pm ] |
tis okay, i have a set of the 3 hole ones otherwise i wouldnt have hacked into them with an angle grinder ![]() |
