Mini K badge info https://www.ausmini.com/forums/viewtopic.php?f=2&t=34397 |
Author: | TK [ Wed Aug 01, 2007 8:39 pm ] |
Post subject: | Mini K badge info |
Hey guys I have a Mk Cooper S badge on the Mini K. I want to replace it with the orginal K badge. Do the mounting holes match? if I have to drill new holes will the old Cooper S badge mounting holes be visable if I change it? |
Author: | simon k [ Wed Aug 01, 2007 8:41 pm ] |
the holes don't match - the cooper badge has holes out on the 'wings' which would be visible if you changed over to a K badge - if you can find one |
Author: | yeehaa [ Wed Aug 01, 2007 10:43 pm ] |
just bog up the holes,sand back the patch where you puttied it,then spray over it,easy brother did it to his bonnet cant tell the difference ![]() ![]() |
Author: | Mick [ Wed Aug 01, 2007 10:45 pm ] |
You didn't say Mk1 or 2, just MK. If it is a Mk2, then it will fit straight away, they are the same. |
Author: | TK [ Thu Aug 02, 2007 1:27 pm ] |
Ooops. Mk 2 Cooper S badge hoping to replace with Mini K. |
Author: | Mick [ Thu Aug 02, 2007 3:12 pm ] |
Yep, straight over, you won't even see the K badge outline as the oval badge will cover it up. |
