It is currently Sun Aug 03, 2025 12:45 am
PostPosted: Fri Aug 03, 2007 3:17 pm
The manual gives the impression they can come apart for serviceing. Anyone done this or know for certain it can be done?
David L
PostPosted: Fri Aug 03, 2007 3:23 pm
y bother throw it away?? and get rid of pollution gear
I have one here from a low milage car if your interested, I have never ran with one on any of my mokes or mini's
monte
PostPosted: Fri Aug 03, 2007 3:24 pm
Yes.
I took one apart, threw away the fossilised charcoal and just stuffed some cotton wool in there (didn't have any charcoal)
PostPosted: Fri Aug 03, 2007 3:27 pm
Theres no parts inside other than the carbon.
If you realy want one on the car to stop the fume smells take a wander around a wreckers yard and check out the late model wrecks - most cars have pretty much the same sized cannister.
PostPosted: Fri Aug 03, 2007 3:28 pm
Can you buy carbon at pet shops ?
Im sure we used to have some in a Fish tank air filter. I 'think' it was replaceable.
That was a loooooong time ago though.
No more Minis!......For now.
PostPosted: Fri Aug 03, 2007 3:35 pm
yes you can buy carbon from your local pet shop because i ran it in my water filter on my fish tank
PostPosted: Fri Aug 03, 2007 4:54 pm
yeah they can come apart, i pulled mine apart to see what was in it. nolonger on my car now though
Brenton
PostPosted: Fri Aug 03, 2007 6:47 pm
Could you use charcoal out of the fireplace for it? Ho do you know if it needs a service (Sally has one and I dunno whethere its ever been touched or not)?
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Fri Aug 03, 2007 7:02 pm
It would be "activated" charcoal - basicall charcoal that has been held at temperature for a period of time (150°C for 1 hour?) This drives off all the moisture and any other volatiles .
From Wikipedia
[edit] Production
It can be produced in two different processes from a variety of carbonaceous source materials, e.g. nutshells, wood, coal. It can be produced using one of the two following processes:
Physical reactivation: The precursor is developed into activated carbons using gases. This is generally done by using one or combining the following processes:
Carbonization: Material with carbon content is pyrolysed at temperatures in the range 600-900 °C, in absence of air (usually in inert atmosphere with gases like argon)
Activation/Oxidation: Raw material or carbonised material is exposed to oxidizing atmospheres (carbon dioxide, oxygen, or steam) at temperatures above 250 °C, usually in the temperature range 600-1200 °C.
Chemical activation: Impregnation with chemicals such as acids like phosphoric acid or bases like potassium hydroxide, sodium hydroxide or salts like zinc chloride, followed by carbonization at temperatures in the range 450-900 °C. It is believed that the carbonization / activation step proceeds simultaneously with the chemical activation. This technique can be problematic in some cases because, for example, zinc trace residues may remain in the end product. However, chemical activation is preferred over physical activation owing to the lower temperatures and shorter time needed for activating material.
Saturated activated carbon can be regenerated by heating.
Not the last line and read in conjunction with my opening comment
David L
PostPosted: Fri Aug 03, 2007 7:07 pm
The charcoal cannister is one bit of pollution gear that does work (not very well!) and does not hurt power.
I would fit it, hook it up and leave it empty!
PostPosted: Fri Aug 03, 2007 7:32 pm
Just scanned a couple of bits from the manual....
PostPosted: Fri Aug 03, 2007 7:41 pm
I dont think Sallys has ever been touched, does this mean I need to change her filter in it?
