It is currently Fri Jul 18, 2025 4:36 pm
PostPosted: Thu Dec 16, 2004 9:40 am
DAMN!! F$%#
OK, so I'm removing the wiring loom from the car, pull the last little bit through the windscreen pilllar (A Pillar??) and snap, I snapped off some wires inside the pillar. Is there anything I can do apart from cutting a hole and welding it up?
PostPosted: Thu Dec 16, 2004 10:03 am
You could try getting one of those long flexible grabber thingo's from bunnings or your local super-bahn-co.
If that doesn't work leave them there... they're not going to do any harm as long as they aren't in the way and the new wires that go past them are shelded.
dewey
dwightgunning.com
PostPosted: Thu Dec 16, 2004 10:23 am
Well I think they will be in the way to feed the new loom through (not that I'm anywhere near that stage). I could just run the new loom up the other side though yeh? I'm mainly worried about the stuff virbrating in there, I'm aiming to make this nice and quiet (on the inside anyway) :lol:
PostPosted: Thu Dec 16, 2004 10:58 am
get an old fishing rod and push it out with that.
aaron
PostPosted: Thu Dec 16, 2004 4:20 pm
Should have tied some cord (venetian blind type) to the old wires before you pulled them out and that would have left a pull through to pull the new ones back. :roll:
David L
PostPosted: Thu Dec 16, 2004 7:32 pm
Forget the fishing, rope, bulldosers, etc.
U need to get scissors and a big screwdriver or prying bar.
Now cut the headlining back just enough to get the pry bar in and start to bend the stuff out of the pillar so you can finish takign the loom out.
Finished product; bent A pillar-complete wiring loom.
PostPosted: Thu Dec 16, 2004 8:11 pm
Did you remember to undo the interior light wire first??
I'm afraid the only way is probably going to be headliner removal... :(
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Dec 16, 2004 8:40 pm
i remember doing this with a mates Fiat 124, but the wires would not come through at all. This was coz the previous owner had bogged the A-pillar and the wire were stuck in it. :shock: No i mean the whole thing. There was no metal at all on the outside, and they had gone to the trouble of filing it to look like the metal contours should before they painted it. :lol:
PostPosted: Thu Dec 16, 2004 8:51 pm
I has 3 Fiat 124 coupes, sold the 1st when it rusted, then cut up the 2nd to fix the 3rd. As you do..
Anyway the LF guard had had a bit of a shunt sometime and the shape was a bit dodgy, so we bogged it. The spraypainter/panelbeater christened it `a sculpture in bog'.. 8)
PostPosted: Thu Dec 16, 2004 8:54 pm
sounds like every other 124 i've ever seen. my mate has been at it for 13 years now, and theres still more bog than metal :lol:
PostPosted: Mon Dec 20, 2004 1:18 pm
There is no headlining or any interior left in the car. I was pulling the loom out so I wouldn't have anything in the way so I could clean it all up ready for painting. The was nothing attached to the wire except maybe a plastic connector to go onto a rear light fitting or something.
