It is currently Thu Jul 31, 2025 6:09 am
 Post subject: Rear Engine / Hand Brake
PostPosted: Sat Aug 04, 2007 1:57 pm
I have a car with a mini engine and subframe assembly in the rear.
All is well except I need to sort out a mechanicaly operated hand brake.
I can fit Cooper S disks or mini drum brakes on the rear, but need to incorporate the hand brake.
Anyone aware of a disk brake caliper with hand brake that may fit the mini uprights?
I want to stick with the 10 inch wheels as I have a set of Dunlop mags.
Any ideas???
PostPosted: Sat Aug 04, 2007 3:46 pm
What's your car ? I'm (slowly :? ) rebuilding the fang below in the sig , my plan is to modify a rear brake backing plate by enlarging the hole in the middle so the drive shaft fits and bolting it on the front hub (now at the rear) . I haven't been able to find any calipers that fit in order to fit discs at the back though after reading Hanra's Honda brake conversion a while ago it would be possibel to use other callipers with an adapter plate on drum hubs . I have some Toyota Corolla Seca callipers for future use for this but am working out the rear backing plates onto front hubs first . Not sure if Morris Minor rear backing plates can be modified easier though as I believe tehy used the same size drum .
PostPosted: Sat Aug 04, 2007 4:55 pm
If the question is about the mechanics of making a handbrake work on disks then a hydraulic handbrake is the go. Fairly common conversion amongst motorkanarist's and mini rallyists years ago. I believe there are still a few cars about with that conversion.
PostPosted: Sat Aug 04, 2007 5:02 pm
The car is a twin engine mini, or twini mini.
I have currently fitted rear backing plates to the hub by turning out the centre hole.
I can use the standard cable, however it runs up and down, not front to back, because the backing plate is at 90 degrees.
I think the original 850 backing plate would do the same job.
Hydraulic handbrake would be easy, however I don't belive this would pass the engineers as it is not independent.
PostPosted: Sat Aug 04, 2007 5:05 pm
Have a look at discs on trailers particularly small wheeled boat trailers.
PostPosted: Sat Aug 04, 2007 5:06 pm
A hydraulic handbrake is not legal for road use.
You must have a mechanically locking system and hydraulics do not pass.
PostPosted: Sat Aug 04, 2007 5:14 pm
Okay meant to add "cable operated" disc brakes on trailers.
PostPosted: Sat Aug 04, 2007 5:15 pm
OK , sounds fun . Fangs when new had the rear backing plate mounted like I described .
PostPosted: Sat Aug 04, 2007 5:16 pm
I might have some calipers here that bolt onto a mini upright.
and have the handbrake mechanism built in
all depends on the size of your rotors
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sat Aug 04, 2007 5:19 pm
What are they Steve ? If there's something available for a reasonable price (I.e, not billet competition only stuff) I could be tempted to go 4 wheel discs earlier than intended .....
PostPosted: Sat Aug 04, 2007 5:22 pm
i have two different calipers to try...
will take them off and do an eyeball inspection during the week.
someone remind me later to post the results
PostPosted: Sat Aug 04, 2007 6:20 pm
these are off a Honda CRX, just about any honda with rear disks from '88 onwards has the same ones.
very nice pad coverage over a mini 7.5" rotor, and has plenty of room under a stock Cooper S rim as you can see
I was quoted $33 each from a wreckers in Melbourne
PostPosted: Sat Aug 04, 2007 8:16 pm
Hi skssgn, The calipers look good inside the rim. Have you tried them against the cooper s uprights???
PostPosted: Sat Aug 04, 2007 8:32 pm
Um, can we see some pics of this vehicle..?
PostPosted: Sat Aug 04, 2007 8:43 pm
Suzuki GTI rear calipers?
